Lowering suspension?
Sep 7, 2009 | 12:23 AM
2nd Gear
I was looking at after market parts and came across a kit that would lower the suspesion an inch. Has anyone been there?
Sep 7, 2009 | 02:09 AM
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Spend a few minutes and search for lowering suspension. Lots of good info that will help educate you.
IMHO start with dropping the rear first. Keep a little rake in the setup. Drive and enjoy..
Sep 7, 2009 | 11:37 AM
I've done this. The rear is easy the front not so much. Car definitely looks better
Sep 7, 2009 | 01:12 PM
Lowering the front is not hard....However, lowering the rear is so simple on a C4 it makes the front look difficult.
How far do you want to drop it. You can lower the front about 1 inch without pulling the spring but for a decent drop the spring has to come out.
Sep 7, 2009 | 01:14 PM
Aboatguy that doesn't cause any problems with turning?
Does it affect ride quality a lot?
Sep 7, 2009 | 03:10 PM
Quote:
Originally Posted by
Pwnage1337
No not with stock tire sizes.......and no I did not notice a change in ride quality ....However, you missed the most important thing..... a quality 4 wheel alignment when done.
Sep 7, 2009 | 05:13 PM
aboatguy
Sep 28, 2009 | 10:07 PM
aboatguy
How do you drop the front without removing the front spring?
