I need a quick answer on heads!!!
Old Sep 9, 2009 | 12:21 PM
87stocker's Avatar
87stocker
Default I need a quick answer on heads!!!
I am going to go .030" over with my 350 to 355inch. I have a first intake and will be going with a new cam of my choice and pistons of my choice. I am looking at selling my almost new trick flow 175cc heads and buying a new set to accomidate more flow. Will a 190cc be too much. I will be porting my intake if needed. Any and all input is welcome. Either PM me or message back asap.
Old Sep 9, 2009 | 01:29 PM
MK 82's Avatar
MK 82
Lots of folks run 195s without a problem.
Old Sep 9, 2009 | 05:42 PM
87stocker's Avatar
87stocker
Yah lots of guys run 195's with bigger cubes, super rams or mini rams (shorter/larger runner systems). Do you think it will work with my FIRST TPI intake. It has very large runners, and they are a little shorter than the factory ones. I dont see an issue, but I just want some of the guru's onboard and juniors with experience to give me a yay or nay/ opinion on my choice.
Old Sep 9, 2009 | 06:04 PM
Master__Shake_'s Avatar
Master__Shake_
How much are you looking to sell those 175cc heads for? If they flow better than the stock 113 heads I'd be interested on a decent price.
Old Sep 9, 2009 | 09:12 PM
87stocker's Avatar
87stocker
I payed 1205 + GST Canadian for them. They have less than 1000km's on them. I would like $950.00 canadian for them.
Old Sep 10, 2009 | 02:26 PM
Master__Shake_
Just a little out of my current price range, and considering I can buy a brand new set for roughly that much I'll have to pass. If you'd be willing to reconsider & provide some flow #s/casting # info, I could possibly offer you $600 USD for them.
Old Sep 10, 2009 | 03:40 PM
BacknBlack's Avatar
BacknBlack
Have you decided on a cam or have an idea what you want?
Old Sep 11, 2009 | 12:35 AM
87stocker's Avatar
87stocker
Yah sometimes I wish I lived in the US just for the performance parts pricing. I will keep that in mind. I thought I had them sold up here, but things didnt go acording to plan.
Old Sep 11, 2009 | 12:39 AM
87stocker's Avatar
87stocker
I havent decided on anything yet. I still want to go 355 ci. I just need to know if 180 cc heads will be enough, will my TFS 175cc be fine with a light port job. And a little advice on a cam. Here is links to both the flow #'s on the heads aswell as current cam specs. I think I may be able to stay with my current cam.
http://static.trickflow.com/global/i...%2C030bore.pdf
http://www.compcams.com/Cam_Specs/Ca...?csid=208&sb=0
Any Advise?
Old Sep 11, 2009 | 03:44 AM
Master__Shake_
That's quite a big cam you're looking at there.. those heads would be better for a milder lift of .520-.530 but that cam would require a heavy port job to make use of those heads. What lift are the springs in the heads rated for? I think TrickFlow went from .480-.540-.600 increments.
I don't know your current financial situation, or other mods you've done to the car, but to be safe I'd back off to a .530 lift cam with slighter lower duration for the low-end torque & keep the 175 heads while possibly doing a touch-up port job on them. I'm not all too familiar with the FIRST intake so maybe that's a decent RPM range, and you've got a lot of support with roller cams as every brand has several selections for them, so come up with a game plan and get back to us on it.
Old Sep 11, 2009 | 09:29 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I think that cam/intake/heads you already have, would work well with the 355 rebuild.
Old Sep 11, 2009 | 09:43 AM
87stocker's Avatar
87stocker
I have the heads built with the dual valve springs for up to .600. I have plenty of low end torque, I was just going to build for a little more get up this winter.
Old Sep 11, 2009 | 09:49 AM
87stocker's Avatar
87stocker
Thank you Agent86. That was the answer I was looking for. Im pretty sure if i remember correctly the heads matched the intake gaskets fairly well. It was the intake that could use some opening up. Is this an art that is best left to people that do it. Or can I work slow and do it myself.
That combined with a few more cubes is probably where I want to be. I just want to have a fresh bottom end aswell as the top end. The motor only has 160000 kms on it but what the heck it cheep enough to do. Also I broke a front timing cover bolt off, and it would be easier to do with the motor out, so I should just go for it.
Old Sep 11, 2009 | 02:54 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I would agree with that -- especially if the springs can handle the XFI cams. (Call TFS is you want to dbl-chk that.) Some call the XFI lobes awfully aggressive, others don't worry. IMO, that can be a product of one's goals.
Comp says their XE lobes are slightly less aggressive -- plus they have an XE cam with essentially the same specs as the 268 XFI. And, there's a high-lift magnum lobe that's one step down from that.
The 195's wouldn't be too big -- if you wanted to go that route. In fact, they could give you a nice bump from 4k rpms on up. Keep in mind, that FIRST is designed to breath for a 400+ci motor. BADSS said it runs with stealth ram (minus 1 or 2 tenths). And, with a stealth, there's no way I wouldn't consider the 195s.
OTOH, if you were ready to swap heads (and pay extra for it), going for a 383 while the block is apart is another option. If mid-range torque is more important (to you) than top-end speed, those 175's with a 383 probably wouldn't disappoint you in mid-range rpms. If you did that, a little more cam wouldn't hurt.
Old Sep 11, 2009 | 04:15 PM
87stocker's Avatar
87stocker
This is a street car to me. It will do 2 or 3 trips to the drags. I would like some good quarter mile times for sure, but mostly street torque is what I want. I may consider a 383 aswell.
Old Sep 11, 2009 | 06:17 PM
87stocker's Avatar
87stocker
OK I was thinking of a set of Patriot heads 190cc,which are 2.02, 1.60heads, on a 355ci motor, with existing 08-466-8 cam. I am going to open the intake up to gasket match(both runners and lower). What is your thoughts on that. I am still planning on the 10.5:1 range. I can go stroker I guess. Its just another big expense.
Old Sep 12, 2009 | 10:00 AM
GREGGPENN's Avatar
GREGGPENN
Are the 190's used? I only see this 195cc option. And, the one I linked is the mininum you could run since the entry-level head wouldn't handle your cam.
To I need a quick answer on heads!!!
Old Sep 12, 2009 | 11:12 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
And then there is the combustion chamber issue. 10.5:1?
Old Sep 12, 2009 | 04:09 PM
87stocker's Avatar
87stocker
There is a 190cc. Link belowThey are a 64cc combustion chamber. Why cant I make 10.5:1. All I need is a flat top pistion. Or am I missing somthing else that was mentioned?
https://www.patriot-performance.com/...5&cat=0&page=1
Old Sep 12, 2009 | 04:15 PM
87stocker's Avatar
87stocker
With the flow #s provided and proof from my speed shop that this is acurate to within 1cfm of posted spec and my cam, and my First Intake. Would I be best suited for a 383 or can I get away with a 355. I have started budgeting both and the price is not that different. Thoughts??
