3:73 rear
Old Sep 11, 2009 | 10:30 AM
joe3906's Avatar
joe3906
Default 3:73 rear
Going from 3:45 to 3:73 rear, is there a significant loss of top end performance? Trying to decide if putting in 3:73 gears is the way to go to complement my other mods.
Joe B.
Old Sep 11, 2009 | 10:39 AM
engle1147's Avatar
engle1147
I don't think you notice that big of a difference between your old ratio and the 3:73. IMO you might consider a HP enhancer instead.....depends on what your after I guess.
Old Sep 11, 2009 | 10:57 AM
pologreen1's Avatar
pologreen1
I heard always go with 4.11 on a 6 speed, that seems to match well, I would not waste time or money on moving that little bit.
do a search many people they should have come with 4.11's
IMO it is what I would do first if I had a 6 speed
Old Sep 11, 2009 | 04:52 PM
mnstrlt1's Avatar
mnstrlt1
The 3.73's are the gears of choice over at the ford camp (when i had a mustang). It seemed to be a good compromised between what the car came with and going "too" short (i.e. 4.11's). The 4.11's almost seem "too short" when you're making ridiculous power (more than 500-550rwhp). This is why the ford guys like 3.73's in the mustang, get's the car going but wont blow the tires off
Although, these cars are definitely geared differently and that 6th gear certainly helps.
A lot of people are concerned about the "top-end", tell me, how often do you plan on going past 160mph? If not often than you won't miss the slight difference on the top-end if you go with 3.73's or (4.11's).....
3.90's also seem to be a common swap for c4's.
Old Sep 12, 2009 | 12:49 AM
whalepirot's Avatar
whalepirot
I still rip tires too much even dropping to 3.54s from (broken) 3.73s.
Now I wish I had gone to at least 3.36; maybe 3.07.
My rear end guy said the lower ratios have more contact area for the teeth, which helps them handle the power AND last longer. I opted for cryo treatment in addition to the gear set he chose for more contact area (sorry, don't have the manf).
Old Sep 12, 2009 | 01:40 AM
_twisted_'s Avatar
_twisted_
either go with 4.10's or don't change
3.73's will feel almost the same as going from a 26.1 rear tire to a 25.5 --- not much of a difference
especially with a ZF6
Old Sep 12, 2009 | 07:30 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Old Sep 12, 2009 | 08:40 AM
tblt44's Avatar
tblt44
Keep what you have and put the money elswhere
Old Sep 12, 2009 | 05:14 PM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Is goin from 2.59 to 3.73 with auto trans too big of a jump?What rpms can I expect in overdrive?Are 3.54 a better choice all stock 93 vert.thanks
Old Sep 12, 2009 | 09:37 PM
Race Prepared's Avatar
Race Prepared
Might not enjoy the 4:11 on the street - mid 3's are a good match for the 6 speed unless you are building a track car.
Old Sep 12, 2009 | 11:23 PM
_twisted_'s Avatar
_twisted_
ks5 we are neighbors I have a 3.07 d36 that would give you a nice improvement over the 2.59's
shot me a pm an we can hook up one of these days
Old Sep 13, 2009 | 01:35 AM
KoKane's Avatar
KoKane
95 6 speed here. Added 4:10s this past winter. I researched and the majority of people said go with the 4:10s. The majority was right!! Go with the 4:10s.
Old Sep 13, 2009 | 01:50 AM
Mrs. glass car's Avatar
Mrs. glass car
I put the 4:10s in 6 years ago, and I waited 7 years too long. I should have put them in the day I bought the car. Better in every way in an LT-4.
Old Sep 13, 2009 | 05:08 AM
rodj's Avatar
rodj
Is goin from 2.59 to 3.73 with auto trans too big of a jump? What rpms can I expect in overdrive? Are 3.54 a better choice all stock 93 vert.
2.59 @ 70 mph = 1660 rpm
3.73 @ 70 mph = 2400 rpm
3.54 @ 70 mph = 2280 rpm
Old Sep 13, 2009 | 08:56 AM
joe3906's Avatar
joe3906
Thiis is a lot to digest, folks; thanks for all the feed back. I was offered a swap to 4:10 a while back by a very reputable forum member.
He also gave me some advise about the swap. He said the Lt4 would be a beast if you add the 4:10 gears. If I go with 4:10 gears I will hold on to my 3:45 so as to be able to go back to stock. Now, to find someone who wants to get rid of 4:10's.
Again, thanks so much for the help, folks!
Joe B.
Old Sep 27, 2009 | 07:27 PM
deadcafe's Avatar
deadcafe
Joe B.
I was just recently talking with a Camaro owner that said he went from aa 3:42 to a 3:73 and stated there was not much of a difference, and wishes he went with a 4:11...... I would go with the 4:11 myself.
Old Sep 27, 2009 | 09:00 PM
thetoy's Avatar
thetoy
I had 4.10's in my car it was great for a somewhat stock motor with headers up until you put some horsepower in the car then I was having to shift to 5th gear to finish the 1/4 mile and that killed my time. I have 3.73 now and love it but also have lots of power now.
To 3:73 rear
Old Sep 28, 2009 | 04:25 AM
Snakecharmer383's Avatar
Snakecharmer383
I just went to 3.73s from my 3.33's and I can even tell on the city streets as well as highway the difference. I'm glad I didn't go 4.11s as I'm blowing the tires off now in 2nd at about 40mph. I do have a 6spd
Old Sep 28, 2009 | 09:10 AM
LT4BUD's Avatar
LT4BUD
Not true...
26.1/25.5=1.0235
3.73/3.45=1.081
Old Sep 29, 2009 | 10:48 AM
5abivt's Avatar
5abivt
Our cars are 5 speeds with a fuel economy 6th. 3.45s are a compromise for best all around gear. 3.73s are the best in my opinion. I had 4.10s. hated it. I have 3.75s now but wish I stayed 4.10s only because my motor went 8k. It was risky enough doing datalog runs in 4th gear to 8k with a 26.2 rear tire 10x a night and 5 more for fun 5th was only good for me for top speed runs and with a peak torque at 5800 rpms 6th was absolutely useless unless I planned on cruising at 180 mph.
are you l98 or lt1?
