Radiator flush/refill!
Old Sep 13, 2009 | 05:50 AM
Phantom_Vette1's Avatar
Phantom_Vette1
Default Radiator flush/refill!
Hey all
i finally got my heater core out of the vette, it's a 90 model! after finding all the hidden bolts argh!!(won't be doing that again)
anyway i am going to flush the radiator and refill it while replacing the core!
My questions are on the 90 model the radiator pressure cap is up near the windscreen! is this where i can refill the radiator? or do i have to take off the plastic cover over the radiator?(is there another pressure cap there?) thanks
also what coolant do i use? i think i read that models prior to 94 don't use antifreeze!? and i do live in Perth W.A so it's not like it gets below 0 degrees C here!
is normal coolant with that glycol... stuff adequate?
Old Sep 14, 2009 | 12:45 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Yes, the 'radiator cap' on the 'surge tank' (black tank near windshield) is where you fill the cooling system.
THere may also be a 'bleeder' underneath the throttle-body (brass regular-screw-driver type).
1990's (and all cars) do require anti-freeze. However, your year does NOT use 'Dex-Cool'. It uses old style 'green' ethylene glycol anti-freeze with silicates.
Suggest either Texaco or Zylex brand, make sure it's their 'old style' green version.
Old Sep 14, 2009 | 01:19 AM
Phantom_Vette1
Thanks, i am glad i don't have to mess around with taking the plastic off! unlike most radiators which have the cap on the radiator itself!, the vette is way better, easier access!
We have coolant that has that glycol stuff and then we have antifreeze!, hmmm i will have to have a look at them at the shops!
Old Sep 14, 2009 | 07:23 AM
LBYRNES's Avatar
LBYRNES
To make sure you are getting the right coolant, it should say
GM 1825M somewhere on the label.
Good luck.
Old Sep 14, 2009 | 03:19 PM
samsonb's Avatar
samsonb
I went with Zerex G-05 coolant as had been recommended here. It is supposed to last longer and not sludge up compared to the green stuff, and isn't a Dexcool clone.
Old Sep 16, 2009 | 03:01 AM
Phantom_Vette1
Ok thanks
i bought an Australian brand for our conditions called Nulon, it's antifreeze, antiboil, and something else, can't recall from memory!
but seems to be the best stuff we have! it's a concentrate so need to add water!
Old Sep 16, 2009 | 06:56 PM
jvette44's Avatar
jvette44
Make sure it is distilled water!
To Radiator flush/refill!
