Camshaft Drive Pin Question
Old Feb 20, 2002 | 09:27 PM
mn_vette's Avatar
mn_vette
Default Camshaft Drive Pin Question
Well, I installed my new camshaft and found out that the drive pin is too long. Does anybody know an easy way to fix this or am I going to have to bust out the hack saw?
Old Feb 20, 2002 | 11:09 PM
onry's Avatar
onry
Default Re: Camshaft Drive Pin Question (mn_vette)
Grap a cutoff wheel and have at it. (if you have one) It has to be cut down.
Old Feb 20, 2002 | 11:44 PM
Oh My's Avatar
Oh My
Default Re: Camshaft Drive Pin Question (onry)
dremels work wonders
Old Feb 21, 2002 | 04:03 AM
GlockLT4's Avatar
GlockLT4
Default Re: Camshaft Drive Pin Question (Oh My)
:yesnod: :yesnod:
Old Feb 21, 2002 | 01:06 PM
DRAGRACR's Avatar
DRAGRACR
I had the same problem with my CC306 and figured that the dowel pin was not pressed in as far as it could go. I took a small hammer and tapped it in so it would clear the timing cover. :cheers:
Old Feb 21, 2002 | 01:32 PM
silver & red CE's Avatar
silver & red CE
The longer pin is for the newer optispark. You can pull the long pin out and install the shorter pin. Tapping it into the cam should work too, but it depends on who made your cam. On the ZZ3 and LT4 Hot cam I have it looks like it should work. The worst thing that could happen is the pin bottoms out before it goes in far enough.
Good Luck,
Eric
Old Feb 21, 2002 | 02:07 PM
BlueDemon's Avatar
BlueDemon
Default Re: Camshaft Drive Pin Question (silver & red CE)
Easiest way is to just tap the pin in some. That's what we did when we put the hotcam in nathan's vette.
Old Feb 23, 2002 | 04:35 PM
mn_vette's Avatar
mn_vette
Default Re: Camshaft Drive Pin Question (BlueDemon)
I tried tapping it in and that didn't seem to work. It's a ZZ-9 cam and I called TPIS and they said just grind it down. So the local NAPA did it for me (don't have my own grinding bench) and it fit great. Thanks for the help guys.
To Camshaft Drive Pin Question
