Change Oil Light
Old Feb 23, 2002 | 05:10 PM
mozot's Avatar
mozot
Default Change Oil Light
What is the procedure to turn off the Change Oil Light in my 95 Vette. I dont have a owner's manual.
Old Feb 23, 2002 | 05:11 PM
scorp508's Avatar
scorp508
Default Re: Change Oil Light (mozot)
I wish I could help you, but I want to say it has something to do with holding the gauges button down for a while. I'm not positive.
I found it...
1. Turn ignition "ON", but do not start.
2. Press the "ENG/MET" button and release, then, within 5 seconds press it again.
3. Within 5 seconds of step 2, press and hold the "GUAGES" button. While the button is held the "Change Oil" Indicator will flash.
4. Continue holding the "GUAGES" button until the "Change Oil" indicator stops flashing and goes out, indicating sucessful completion of the reset cycle.
**This should take about 10 seconds
**If it is not successful, turn ignition off and start over with step 1.
[Modified by scorp508, 4:12 PM 2/23/2002]
Old Feb 23, 2002 | 05:14 PM
mozot's Avatar
mozot
Default Re: Change Oil Light (scorp508)
Thanks a lot, the best thing about owning a Vette is that there are so many people out there who can help you. Thanks again:)
To Change Oil Light
