Can these units be modified / programmed / tuned like the original equipment or do I need to find a original 92 unit off of fleabay ?
Is exactly the same as the original unit. Has a chip (memcal ) inside that can be reprogrammed or more commonly replaced with a chip holding your new tune.
Its actually going to TPIS in Tempe (The entire car). They are local for me.
I would do the PCM for less however I do not have flow numbers for the heads and in order to get a good tune they would need to know how much they actually flow.
TPIS being local (with a dyno) I can get all the mods done , flatbed the car to their shop and drop it off.
