e-brake
Old Sep 14, 2009 | 04:55 PM
mike bys's Avatar
mike bys
2nd Gear
Default e-brake
I just bought a 96 special edition, 34,000 miles, 6 speed. The previous owner thought the cable was cut, but upon inspection all is intact. It apparently needs adjusting, but my mechanic did not see a way.
Anyone have experience with this?
Old Sep 14, 2009 | 05:26 PM
pianoguy's Avatar
pianoguy
I believe it self-adjusts by engaging/disengaging it several times. What is it doing/not doing?
Old Sep 14, 2009 | 05:35 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I don't think I still have the instructions that came with my new E-brake handle.
You can leave it normal or remove the small screw to make it adjustable. Unless you remove the screw, it will not self-adjust.
Old Sep 14, 2009 | 08:38 PM
pianoguy's Avatar
pianoguy
If they still don't grab, it could be that the rear brake pads are worn out. Otherwise, there is a procedure to adjust the cable. This thread lists it in general, though some steps aren't applicable since your car doesn't have separate shoes for the parking brake. There's a better thread somewhere with drawings from the FSM, but I can't seem to find it:
http://forums.corvetteforum.com/c4-g...post1560187929
To e-brake
