Help identifying Relay's
Old Sep 15, 2009 | 06:15 PM
tblt44's Avatar
tblt44
Default Help identifying Relay's
1995
I am still looking for my lighting problem.
What are the 3 relay's for directly under where you fill the coolant?
Also there are three relay's on the left side of the radiator shroud,I know 2 are for the fans ,what is the third for??
My interior lights only work with the overide switch
All bulbs and fuses are good,door switches also good.
thannks
Old Sep 15, 2009 | 06:33 PM
MK 82's Avatar
MK 82
There are 3 fan relays on a 95.
Old Sep 15, 2009 | 06:37 PM
tblt44's Avatar
tblt44
Ok then the 3 up front are for the fan I guess.When hooking up a manuall fan switch you only hook up to 2 of them.
To Help identifying Relay's
