turn signal question
Old Sep 15, 2009 | 09:32 PM
gmcs88vette's Avatar
gmcs88vette
Default turn signal question
My passenger side turn signal quit working. I replaced bulbs but still not working. Bulbs will light. Flasher makes ticking noise when drivers side is on so I dont think its the flasher. Any thoughts or recomendations are welcomed.
Old Sep 15, 2009 | 09:39 PM
JackDidley's Avatar
JackDidley
Try it with the steering column tilted up and down. When mine did that, it was a naked wire that would short when I tilted the column down.
Old Sep 16, 2009 | 12:16 AM
jfb's Avatar
jfb
Look at the lamps that are flashing on your driver side and then look at the same lamps on the passenger side. The flasher works on current, more current faster flashing, low current, slow or no flashing. My money is on one or more lights not being lit.
Old Sep 17, 2009 | 12:35 AM
josephf31's Avatar
josephf31
Default When
you use the emergency flashers do the passenger side bulbs flash? If so it's not a bulb problem.
To turn signal question
