pushrod advice needed
Old Sep 16, 2009 | 11:13 PM
Qiken's Avatar
Qiken
Default pushrod advice needed
Are all 7.200 X 5/16 pushrods same for 87 up roller's??
Old Sep 16, 2009 | 11:45 PM
rodj's Avatar
rodj
7.2 is the stock length for factory roller lifter.
Supposed to check required length after install; some aftermarket roller rockers may require shorter
Old Sep 17, 2009 | 12:01 AM
Qiken's Avatar
Qiken
Im replacing OEM cam with the zz4,1.52 comp cam rollers and installing lt4 hot cam springs,thought I would thro in some new pushrods as well.
Old Sep 17, 2009 | 12:21 AM
Weav's Vet's Avatar
Weav's Vet
I was told by Lloyd E. to use 7.100 length with the cam I ordered from him if not measuring but he also said it is best to measure for accuracy. This was on an LT1.
To pushrod advice needed
