Nope...he didn't get those from me. Mine are still sitting in the shed with 6 year old super-soft Goodyear Eagles on them
If you ever want to sell them let me know...
Originally Posted by 1991Z07
I hear you about the seat time...too bad you aren't closer to us here in Texas. You could have some fun on the Open Road Races and REALLY get a thrill ...59 miles of flat-out, fast as you have cojones for (or your car is teched for) fun.
Nevada does a few every year as well...THAT is worth the price of admission! We have a few good NASA events down here every year, too...about 6/yr. TWS and Hallet are the best...
I am taking next year off of racing to help pay for my wedding but when I get back into it I would love to travel wherever I can to experience all the tracks I can.
The only thing you really need to modify is the body. Back to stock.
Whats up with that? you don't have to be a @$%& about it. It's not my first choice of bodywork but its unique and I didn't pay a fortune for it.
And the whole post on "Doing stuff out of the box" I'm just working with what i have, I didn't say i wanted to weld wheels or throw a 335 on a stock wheel. I realize that i need a 12" wheel for a 335. The whole point in this post was to get an opinion on what Offset would be required.
I would say from your other post if you want it to stick out 1 inch wider than the 36mm ZR1 offset and you want a 12" wheel, it has to be a 23mm offset. If you want to stay with the 11" wide wheel it needs to be an 11mm offset.
There's no other way to say what offset you need other than measuring.
You could measure with one stock wheel or whatever you've got if you know what offset is that wheel and go from there.
learn to ignore people's opinions here(some here are just old fashioned), unless it is tchenical advice, there is a mixed bag of tricks on that but you can sort through a ton knowledge and experience to get things handled.
I'm not trying to be a douche. just trying to help out and steer you in a better direction. I just think instead of working with a problem why not eliminate it and be better off.
Anyhow if you insist just listen to the others and measure. theres a lot of brands out there that share the same bolt pattern but have drastically different offsets. One of them may work for you (ie bmw)
i wanted to run BMW wheels as well (yes the 5x120 bolt pattern WILL fit). But BMW's usually come in widths like 8"-10"... so you'd need to touch base with a knowledgeable wheel guy to make sure that the narrower wheel STILL complies with your goal.
Spacers bad,,,,adapters good. Theres a big difference. You can buy hubcentric adapters that bolt to you existing studs and provide their own studs to bolt your wheel to,,,,much safer. I would not run a spacer on long studs,,,,looks scarey. My 2 cents. As far as what wheels,,,should have did some measuring before previous owner pulled his wheels/tires off. Or ask him/her if you can measure his wheels for offset/back spacing. Cheers
