any sugg.s need help
Old Feb 21, 2002 | 10:09 AM
flubuyu2's Avatar
flubuyu2
Default any sugg.s need help
still same code(36) she's a 1993 six speed .it's strange,she starts fine runs up to temp. then dies.no stumble till warm then thetach jumps all around and she just quites,will only start again after about half hour then runs for a shorter time because closer to opperating temp hits that then dies???help!!!
Old Feb 21, 2002 | 12:27 PM
flubuyu2's Avatar
flubuyu2
Default Re: any sugg.s need help (flubuyu2)
anybody??need some ideas on at least what to check! [IMG][/IMG]
Old Feb 21, 2002 | 12:59 PM
Red Dwarf's Avatar
Red Dwarf
flubuyu2,
Looks like you have a problem with the opti-spark, faulty high or low resolution pulses.......?
Old Feb 21, 2002 | 03:50 PM
flubuyu2's Avatar
flubuyu2
Default Re: any sugg.s need help (lou sylvestri)
ya lost me resolution? is that a malfuction with the eye itself?
Old Feb 21, 2002 | 08:11 PM
Red Dwarf's Avatar
Red Dwarf
The opti supplies two timing inputs to the PCM. A high & a low. The PCM compares the two & can determine if one is not being received. Seems like your opti is
failing or perhaps a bad connector?
Code 36 relates to the high resolution signal.
Code 16 would relate to the low " ".
Old Feb 22, 2002 | 10:27 AM
flubuyu2's Avatar
flubuyu2
That sounds like it is probably ti....(sad)it would explain the tach jumping around and the failure after warm up thank you for the info lou.....guess i'll try and get ahold of the gentleman named jeff everyone is calling for parts and see what kinda deal i can get.Saw another thread concerning optic alturnatives and he stated a deal($)that was smokin wish me luck and again thanx for the help.
Tony
To any sugg.s need help
