LT4 - Top end noise
Old Sep 17, 2009 | 05:29 PM
quiksilver458's Avatar
quiksilver458
Default LT4 - Top end noise
Well my recent LT4 purchase looks like it will be costing me even more money. It is a good thing I hardly paid anything for it. Today I diagnosed part of the top end ticking noise I was hearnig at idle.
I removed both valve covers and inspected the lifters. The rocker on the right side of cylinder #7 was very loose. I tried to tighten it but the nut will not go any further. A close inspection showed me that something has got to be wrong in there. I removed the rocker and noticed some wear marks on the roller tip end where it meets springs. I removed the pushrod and it appears to be straight as an arrow. It also appears to be extended the same length as the others eliminating the possibility of a collapsed lifter. I inspected the spring and could not tell if it is broken. It does however look more compressed even though there is no pressure on the top. Can anyone give me any insight to this? At this time I am assuming the worst - a bent valve.
Old Sep 17, 2009 | 05:53 PM
pr0zac's Avatar
pr0zac
pictures would be great..
Old Sep 17, 2009 | 06:00 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If the valve was bent the car would have been running on 7 cylinders, so a dead miss would have been apparent. Can you pull up on the valve, usually with a broken spring you can move the valve. How does the top of the valve look, mushroomed?
Old Sep 17, 2009 | 06:20 PM
quiksilver458
Working on the photos as I can not seem to get a clear shot of it. As for pulling up on the valve. I had pulled and pushed and I can not make it move either way. I just fired the motor with cover off to see if it was in fact moving. The push rod is extending and rotating the rocker which does apply some pressure to the valve, but the motion of the valve seems very short. The valve looks normal. No mushroom affect or anything. Looks shiny and new to me.
Old Sep 17, 2009 | 06:42 PM
quiksilver458
These are the best I can do. I have taken 30 plus and can not seem to get it where it shows the right valve sitting lower than the left. It is not much, maybe 1/8-1/12th of an inch. It is just enough to allow the rocker to come off roller and swivel to either side.
Old Sep 17, 2009 | 07:06 PM
MK 82's Avatar
MK 82
Hasn't exactly had regular oil changes.
Old Sep 17, 2009 | 07:53 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
You said you got it for next to nothing, and now you might know why.
Old Sep 17, 2009 | 08:21 PM
mtwoolford's Avatar
mtwoolford
on my lt4 high miler the valve gear was in good shape except for one lifter; the rocker body where it forms "ears" next to the roller tip had been worn down and damaged by the tip of the valve stem; this was a self perptuating failure because these "ears" locate the pushrod and serve the same purpose as more conventional "push rod guide plate"; as these ears are worn or become damaged, the more the rocker arm wants to rotate off the valve stem tip, and the faster the failure cycle accelerates. There may be something similiar happenning with your engine.
Also, one idiosynchrousy of the lt4 (versus the lt1 or any other chevy small block built since 1955) is that the rocker arms are mounted on a pedestal type mount and the mounting nut, once tightened, allows no further adjustment.
Good luck with your lt4, its a magnificent, albeit expensive, engine in what was arguably the best c4, but truthfully, if money is an issue I would consider an earlier car with an L98 (conventional) engine.
Old Sep 17, 2009 | 09:04 PM
quiksilver458
Yeah - for a 93k mile motor - it sure doesnt seem like it has been mechanically taken care of. Cosmetically, this thing is an easy 8 out of 10. The paint is perfect with the exception of some minor sun damage to top of rear clip. The interior is very clean with minimal wear on the driver seat bolster. I will most likely replace the cover to make it perfect.
Anyway - I pulled a few more push rods and it appears there is quite a bit of build up in the motor. Perhaps this buildup has stuck the valve some? I'd hate to have to remove the head for something stupid like that, but it almost sounds like its my only choice.
I may check autozone and see if they have a spring compressor loaner tool I can rent. Pull the springs, and mess with the valve some. See if it can pull out further than it is.
Old Sep 18, 2009 | 01:14 AM
lt4obsesses's Avatar
lt4obsesses
One thing you might try, although there is a chance that this really uncover any problems in the engine. But those would come to surface eventually.
Try the SeaFoam treatment. Put 1/3 can in the crankcase, preferrably with fresh synthetic. Change after about 200 miles. If your not familiar with it, it is a petroleum based product that cleans sludge and oil varnish. It appears you have quite a bit of that going on, and it could be causing a lifter to stick or clogging the oil passage through the push rod.
You can also put 1/3 gan in the gas to clean injectors and fuel lines. And then slowly suck the rest of it through the brake booster hose to clean out the heads and valve seats. If you search "seafoam" I know there is a tutorial on here. It works pretty well.
As far as the rocker nuts, in the LT4 they are non-adjustable. They simply torque to 18 ft lbs.
Old Sep 18, 2009 | 01:41 AM
Ed Ramberger's Avatar
Ed Ramberger
That's kind of an exercise in futility. The valve spring exerts more pressure than you can.
Old Sep 18, 2009 | 01:46 AM
Ed Ramberger
Omit "regular", replace with "any"
Old Sep 18, 2009 | 02:22 AM
pr0zac's Avatar
pr0zac
i would add quite a few engine cleaning additives to that motor... possibly ATF.
Old Sep 18, 2009 | 05:32 AM
Weav's Vet's Avatar
Weav's Vet
And not just once. That thing is awful! It's a wonder all the lifters aren't clacking.
Old Sep 18, 2009 | 12:54 PM
IRAraid's Avatar
IRAraid
Default Valve travel
Measure the travel of the push rod while cranking the engine and compare it to another valve's push rod travel (both either intake or exhaust). The cam is likely wiped at #7.
Old Sep 18, 2009 | 01:08 PM
pr0zac's Avatar
pr0zac
if i were flushing the oil a few times i wouldn't waste the money to do it with synthetic. yes
Old Sep 18, 2009 | 03:25 PM
quiksilver458
No doubt it has not seen regular oil changes. I suppose I should have added that this car has been sitting for 1.5 years as well. So I know there is a great deal of build up in there. From the previous post - I will be running some seafoam through the system as soon as the new water pump arrives.
Thanks everyone for the advice!
To LT4 - Top end noise
Old Sep 18, 2009 | 04:37 PM
RacerX70CC's Avatar
RacerX70CC
and DON'T DRIVE IT the first time you do this... run it for about a half hour to 45 minutes and change oil and filter.
I never recommend driving with any flush agent in the crankcase for any length of time.
Old Sep 20, 2009 | 08:11 PM
lt4obsesses
It might be a good idea to drain the old oil through a filter of some type to see if there is metal in it. Also let the old filter drain and cut it open. If there's a fair amount of metal in the oil somethings getting chewed up in there.
I just don't get how someone can have a car like that and just totally neglet things like oil changes.
Old Dec 3, 2009 | 08:27 PM
quiksilver458
Well here is an update guys. I removed the heads and discovered the culprit to my problem. A valve seat had fallen loose preventing the one valve from closing completely. Both heads were removed and reconditioned here locally. I of course had a few extras done since they were off and all. Anyway, the reassembly has begun and I have a question.
The hard coolant line that bolts to the rear of each head has my stumped. When I removed the banjo style bolts, both head had two rubber/metal washers installed. These washers are the AC line style washer and did not make sense to me in that location. What washer IF any should be on these two bolts? If a banjo bolt had a washer, it would be copper if I am not mistaken.
Thanks!
