Transmission Cooler...
[Modified by RadPolo96, 1:25 PM 2/21/2002]
Cost was only $80 and its easy to install, although it did take me about 3 and a half hours the first time.
Not sure about your car, but 87 has a cooler that runs into the radiator, down the pax-side tank, and out the bottom of the radiator, almost no cooling ability what-so-ever.
It very cheap insurance to an expensive repair.... get the largest one you can fit.. mine was app 10" x 18" x 3/4" thick..
The cooler cost app $70 + maybe $10 for extra hose & clamps...Ralph & I did it in about 2-3 hrs. If you get a smaller one you can mount it directly to the power steering cooler, but if you do this MOUNT IT as HIGH as you can... My first one that I had mounted there was crushed by a rock on the Tappan Zee Bridge..
Also with the small cooler, & my 2800 converter, I was still getting high trans temps in traffic, or going UP long hills in hot weather..
With this new larger cooler, we mounted it TO the air conditioning condenser... it is actually BETWEEN the radiator & condenser..
To hook it up is easy, just connect the hoses to the factory cooler, (use them both) the BIG PIA is getting your hand between the radiator, & condenser to mount the new cooler... we had to struggle but it CAN be done... & the larger cooler is worth all the work to install it... today in 45 deg weather my temp never went over 140
In the summer its around 190 deg TOPS..
So you have tranny fluid running through the factory cooler too?
I'm guessing a 26,000lbs should be fine for a 3,000rpm converter too. Hopefully not much more heat.
[Modified by Raysur, 9:54 PM 2/21/2002]
[Modified by djpearn, 7:05 PM 2/22/2002]
Simple reason was John has a BPP air intake on the car and yop don't want to introduce heat in the same area your drawing your cool intake charge form.
Thnx
