Please recommend outer tie rod tool
Old Sep 19, 2009 | 03:53 PM
Chatman's Avatar
Chatman
Default Please recommend outer tie rod tool
The local parts stores are Kragen with a variety of pickle forks and NAPA that has a separator 775-9096
http://www.napaonline.com/NOLPPSE/(S...096_0006537798
Will the Napa part work or do I need to use something different?
Old Sep 19, 2009 | 06:42 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Linky, no worky
Do you own a 2 jaw puller ?
Old Sep 19, 2009 | 07:28 PM
JackDidley's Avatar
JackDidley
put the castle nut back on upside down to protect the threads and use a BFH. Yes I'm a savage but some times a BFH IS the tool that works.
Old Sep 19, 2009 | 10:37 PM
96GS#007's Avatar
96GS#007
Also, squirt a little penetrating oil around it before giving it a whack. Works every time.
Old Sep 19, 2009 | 11:09 PM
Weav's Vet's Avatar
Weav's Vet
If you're changing them out it really doesn't matter how you get them apart. The BFH works pretty good!
Old Sep 20, 2009 | 10:28 AM
Chatman's Avatar
Chatman
Thanks for the replies. Tried the upside down castle nut and whack with a hammer -- I used an upside down large bolt to distribute the force. It worked and no damage done.
Between college football and my being convinced that the first hydraulic line went in the other hole, I managed to get the new rack in, steering attached and hydraulic lines connected. The rest shouldn't be too bad except for the back, passenger side bolt.
To Please recommend outer tie rod tool
