84 Vette Rear Spring
Old Sep 19, 2009 | 07:27 PM
Redneckjc's Avatar
Redneckjc
7th Gear
Default 84 Vette Rear Spring
Hi Guys, I have an 84 C4 & it leans (sags) to the left in the rear & i've seen other 84's do the same thing/Is this the rear spring ? It has all new shocks & same size tires !
Thanks for any advise ! Jim
Old Sep 20, 2009 | 10:28 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
just adjust your spring bolt on the left side. (shorten it or, lengthen the right side) after which you will have to have the rear end aligned.
Old Sep 20, 2009 | 10:49 AM
Redneckjc's Avatar
Redneckjc
7th Gear
Default Corvette Rear Spring
Thanks, I'll try it ! Thanks, Jim
Old Sep 20, 2009 | 01:02 PM
383vett's Avatar
383vett
You can turn the spring around left to right to see if it is the spring, the adjust the longbolts.
Old Sep 20, 2009 | 02:33 PM
SmokinRide's Avatar
SmokinRide
that's what i did, when i had the spring out for pad repairs, i flipped the 135,xxx mile spring left to right, the leading edge was subject to road debris and a heavy PO, on the driver side, flipped it over and it even out the car,
simple trick saved a bunch of money, now the pass side is not preloaded as much and the driver side is doing the work, my theory one side overworks with the weight of the driver,
but i could be wrong and these springs never fatigue anywhere...
Old Sep 21, 2009 | 05:59 PM
85vette-84vette's Avatar
85vette-84vette
Does it sag when your in the vette only. A little exercise could cure that.
Old Sep 21, 2009 | 08:35 PM
383vett's Avatar
383vett
Come on. Man up. Tell us you weigh 400 lbs.
Old Sep 21, 2009 | 08:42 PM
Redneckjc's Avatar
Redneckjc
7th Gear
Default Rear Spring
Sorry Guys, I only weigh 195/You guys really think your Funny !
To 84 Vette Rear Spring
