CCM Possessed
Old Sep 20, 2009 | 09:52 AM
rickso84's Avatar
rickso84
Default CCM Possessed
my '91 has an intermittent no-start condition which I think is related to the CCM. When in no-start mode, power and ground pins measure as expected. When car is working normally, ground pins "float" at around 50 Ohms to chassis (not the 2 Ohms that I'd expect)! This is completely backwards from what I'd expect.
I'm really stumped.
Old Sep 20, 2009 | 11:07 PM
rickso84's Avatar
rickso84
Did some thinking... the odd resistance was due to a small voltage drop between chassis and the CCM ground pins. WHen the CCM is working normally, it's drawing some current, and the resistance in the ground lead is developing a small voltage i.e. 15mV, which is messing up the resistance measurement.
THat said, when the CCM is NOT working it's not drawing current and I get stable resistance-to-ground measurements of about an Ohm. Since it appears the CCM is always drawing some current, don't know what causes it to shut down, unless it's supposed to go to sleep and it is when it shouldn't be. Some of the CCM inputs i.e. door switch, headlight switch, are called "wake up" inputs so maybe it's supposed to sleep. Going to try measuring through an open window without waking the CCM up by opening a door and see if it's sleeping.
Anyone out there know what makes a CCM tick?
Old Sep 20, 2009 | 11:38 PM
96GS#007's Avatar
96GS#007
Extremely rare for a CCM to fail. Intermitent no starts are typically one of the following...
- Worn ignition key (the resistance pellet wears over time)
- Worn contacts in the ignition lock tumbler
- Loose and/or dirty wires at the starter.
My money is on the first one. And yes...the CCM goes to sleep just like you described otherwise it runs the battery down over the course of a few days to a week.
Old Sep 21, 2009 | 04:00 AM
jeffp1167's Avatar
jeffp1167
you know my 90 has some black box which looks like a vats decoder box mounted under the passenger hush panel. when this thing is unplugged the car will not start.
anybody know what this is? It is mounted to a plastic panel all by itself and doesn't look aftermarket at all.
Old Sep 21, 2009 | 06:57 PM
rickso84's Avatar
rickso84
Not sure what that "black box" is but could be related. The CCM connects to just about everything in the car anyway!
As for the key pellet idea, I have two keys and both exhibit the issue. Since one's a spare, both don't have the same wear. A "no start" for a bad key makes sense but I've got more symptoms than that. Even without key in ignition, interior lights will all go out on their own (well within the timer interval) or not come on when I open a door. Speedo/odo and backlight will go out sometimes. Won't start when either scenario is present.
Appears the CCM is going to sleep when in shouldn't and not waking up when it should. Sounds like a typical teenager!
Going to list all the "wake-up" and "sleep" conditions and try to verify they work correctly. May give me some insight. I can buy a CCM and have it programmed for $250 total but I too have read that its failure is rare so that'll be a last resort.
Old Sep 21, 2009 | 11:45 PM
gw962's Avatar
gw962
It sounds like a VATS bypass box if the car won't start. The previous owner probably had probems with the switch or key and took that route to a cure.
There should also be a two wire dead end connector hanging out there that comes from the ignition switch. You can use a VOM to check the resistance of the bypass and then check the reading from your key on the connector from the switch to see if they're the same. If you want to take it to a stock configuration, you can troubleshoot from there. Otherwise, don't worry about it, although it will be easier to steal.
Old Sep 22, 2009 | 08:01 AM
jeffp1167's Avatar
jeffp1167
No it's not that ... It plugs into the dash harness and I see no splicing and how its mounted that appears factory to. I will look at it for numbers when I get a chance.
Old Sep 22, 2009 | 08:27 AM
-=Jeff=-'s Avatar
-=Jeff=-
Also the CCM is a Silver (metal) box on the tunnel behind the radio
Old Sep 22, 2009 | 11:59 AM
jeffp1167's Avatar
jeffp1167
Okay here is the plastic box that if unplugged my car wont turn over or anything. It is mounted to a inner dash panel I think that mounted a set of 3 relays I cant remember. Its definitely a factory thing though and only part numbers on it are AC 25075065 37EB
I believe its just the cruise control module, but why would the car not start with it unplugged?
To CCM Possessed
