cooling fan
Old Sep 20, 2009 | 03:29 PM
ndanl's Avatar
ndanl
Default cooling fan
I have a cooling fan that starts when i put the contact, even with a cold engine, is it normal ?
thanks.
Old Sep 20, 2009 | 07:13 PM
rodj's Avatar
rodj
Usually indicates a problem with the ECM; memcal loose , bad connections , etc
Old Sep 21, 2009 | 05:02 AM
ndanl's Avatar
ndanl
what would be a good cost effective way to access the ecm codes and do some troubleshooting ? buy a code reader with aldl interface or just buy an aldl cable and connect it to a computer ?
Old Sep 21, 2009 | 05:13 AM
toptechx6's Avatar
toptechx6
See this link for the paper clip method. Many fault codes will cause the cooling fan to run continuously with the key on. For best results use the correct Factory Service Manual to troubleshoot the codes you retrieve.
http://www.corvettebuyers.com/c4vettes/ecm.htm
Old Sep 21, 2009 | 02:40 PM
Sweet 90's Avatar
Sweet 90
Turn off your HVAC, does it still do it?
Jim
To cooling fan
