TPS symptoms
I was wondering and hoping for some input on a TPS.
Looking for the things that tell me when it is going/inaccurate.
It is set right and i do not have a code from it but what i have read, the TPS may still be my issue.
What normally "acts-up" when this is bad?
This is what i have:
Irratice idle
Surging at idle (more cold then warm)
Hard to start when cold.
loss of power at higher rpm's
Overdrive seems to kick in early
Seems to run rich.
Possible, heats up faster
I have never changed this. 150,000 KM, auto.
Some of the problems also sound related to leaky fuel injectors.
Threw a volt meter on it and moved it by hand, I could see the voltage jump around. it was not smooth at all. my idle voltage was right, it was when I moved it it would jump all over the place.
Replaced it and all was fine.
However, some of your other symptoms do point to the AIC motor. it could have gone bad. it could be coked up with carbon.
best thing to do is test the tps sensor. check for smooth voltage increase as you open the throttle.
next would be to remove the AIC motor, clean out the TB with TB cleaner. get in the AIC passage, and in the blades etc...
decide if you want to buy a new AIC, or clean the tip up a little and reinstall. do the idle reset process, and see what you have.
My mech put new plugs/wires/points/cap/rotor/IAC..cleaned the intake timed, and probably more I missed..
my service engine light is still on..I did not replace the TPS.
Motor runs smooth and strong once it starts to rev.
The idle is still rough tho.
Can my mech just clean and adjust the TPS ?? or is replacement necessary (how much) ??
The adjustment part I don't understand.
I tried to read the manual but I'm really not a mech myself.
My local shadetree is a great mech but doesn't have a lot of experience with the TPS on a corvette.
Plus he's a Ford guy anyway..oh well
I need an idiots guide to TPS to show my guy..!!
Oh yeah..the idiot part is for ME not Jimmy
What i have done since.
Installed a IAC that i had from years ago (thought it was a issue years ago) but it wasnt.
Had a hard time starting the engine, turned the idle screw on the Holly TB to full just to get it to 600 rpm (still ran like poop).
Disconnected the TPS and it made no difference in idle or responce ,but the "check engine" light did come on. WOW!
Ordered the TPS for 80$ at the dealer because my meter shows it as bouncing all over the place. It may just be my meter (digital) slow to respond.
Am i on the right track?
at idle the sensor should be in the area of .54-.58 volts. as you push it wide open, it should reach 5.0v or close to it. Increasing along the way.
I dont know anyone who has cleaned one. usually replace since they are a sealed unit.
If you washed the engine, it is usually a good way to ruin one quick.
The IAC motor completly different from the TPS sensor, this is just a motor with a pointed tip that seals off a port in the throttle body for air to pass through at idle. as the tip moves away from the port, the idle goes up because air is allowed in.
Usually the port, and the tip get gummed up with carbon and the computer adjustment no longer works. this carbon needs to be cleaned out. once done, the idle may go higher then it is suppose to, so one would do the IAC reset process to get the idle set right. It depends on who has done what to it, such as tried to set the idle by turning the throttle body screw in or out without knowing what they are doing.
I found after doing the idle reset, I got the best idle the car has ever had out of it.
As for you check engine light. we need to know what the code is to move forward. this could be leading to a bigger problem.
did you do the idle reset that was posted in the link?
did you see any carbon on the old IAC tip, or in the throttle body? Any attempt to clean it out?
Good luck with your '87
Rod Thx that's my answer !!!
Bill also Thx, it's showing code 23
I'm gonna exit stage left, start a thread and find the fix.
Cheers gang
Could not get .54 volts. .46 Max
Put the old TPS back on and got .54 volts easily.
Crap new TPS.....figures!
3 hours time $100 for TPS as well.......argh!
Stuck with the old TPS
Idle was smooth, will go for a test drive tomorrow and post.
1) Remove the entire throttle body, replace the IAC (there is no way I can get the IAC out without removing the TB...no way you can get a 32mm open end wrench in that space), clean the throttle body real good, etc. I could also dump $100 for a new TPS.....put it all back together and see what happens...
2) Take it to a vette INDY shop to work it.....they may try the same things??
Thoughts? Thanks!
An idle surge can be caused if the return voltage rises above above .62 volts. It's a 3 wire harness: Reference, Return and Ground. Should the Return intermittently come into contact with Ground - (and it only takes a nanosecond as anything much longer than that will set a Code), voltage signal will rise and cause the Surge - ECM thinks its accelerating. So, examine the Connector and make sure it's in good shape - wriggle it around - check harness for bare wires.
has been running pretty well since then...... until recently.....each day it has gotten worse and worse....
I set the min idle by adjusting the set screw till the IAC counts are about 15-25 give or take with all the ascessories off. After that, I set the TPS. The thing about the scantool is you can see TPS voltage. It MUST be a smooth climb as you gently hit the gas. Any hiccups or spikes or drops and you need a new TPS.
