Timing mark on harmonic balancer not visible
Old Sep 24, 2009 | 12:52 PM
bc87corvette's Avatar
bc87corvette
Originally Posted by pletzvet
A simple visual inspection of the harmonic balancer while still on the crank snout will tell you whether it has slipped or not. The link that Floridamale provided shows excellent pictures of one where the outer ring has slipped backwards toward the timing chain cover. Mine actually slipped back so much that it was rubbing the TC cover until it wore a hole through the cover. An oil leak was the first indicator that something was wrong. It is pretty unlikely that the outer ring will turn on the inner ring. When the outer ring slips backward toward the TC, you will not be able to see the timing mark at the timing tab because the ring will be quite a bit behind the timing tab.
Looking at the pics in Floridamale's link.... I see what you mean. Should I be able to see this without removing the pulley?
Old Sep 24, 2009 | 03:29 PM
bomar76's Avatar
bomar76
Trust me, the outer rings CAN and DO turn on the inner ring.
Not uncommon at all.
Old Sep 24, 2009 | 04:36 PM
86PACER's Avatar
86PACER
Yes. This is what a slipped balancer looks like:
First pic shows a good balancer. Blue and Red lines line up. Outer ring is flush with center mounting hub.
Also note the free space between the back of the balancer and front timing cover.
Second pic shows slippage with green arrows. Outer ring and hub are no longer flush. Balancer has backed up
all the way against the timing cover.
On a good balancer, the edge of the timing tab teeth are about half way over the balancer.
This can be used as a convenient visual reference as well.
I tried setting the number one piston at TDC and I don't see the mark, so everything points to a bad hb. Thanks for help guys!
Sound like your balancer might have slipped 180 degrees.
Rotate the engine by the crank bolt with a socket. Smear white toothpaste or some white pipe sealant into the timing mark cutout of the balancer once you find it. Wipe the excess by hand and now only the timing mark should be perfectly white, and try timing again. If you still can't see it, loosen the distributor clamp bolt and rotate the dist both ways while you flash the timing light. If the mark still does not come into view, you probably have balancer slippage. You can tell that by just looking to see if the outer balancer ring (the one with the timing mark cutout) is flush with it's center mounting hub. It should be flush.
Don't put off replacing a slipped balancer. It will slide back wards and start to grind against the timing cover. Leave it like that long enough, and it will eat a hole through it, cause an oil leak, and toss metal shaving into your motor oil.
This is the EST plug you disconnect prior to setting timing. Will set a trouble code. To clear, disconnect the battery for a few minutes and reconnect:
To replace, rent the balancer puller and installer from Autozone.
It's basically free, you leave a deposit and get it back
once you return the tools undamaged. The puller looks like a steering wheel puller and works the same way. This is the installer pictured below.
The upper steering rack line needs to be disconnected and moved to the side to make room for both tools. Turn the installer shaft with a deep socket slid over the end instead of an open end wrench from the side. A deep socket acts as a cup, shielding the threads from scraping/damaging against the steering rack as you turn. Use a crowfoot with extensions to easily disconnect this fitting from above. This fitting DOES NOT have an o-ring in there. It's the opposite ends of the line that do.
Old Sep 24, 2009 | 11:24 PM
pletzvet's Avatar
pletzvet
I defer to the expert...myself being a hobbiest and enthusiast and not a professional in the trade there are no doubt others who have seen more slipped HB's than me. The slip backwards toward the TC is really evidence enough that the HB needs replaced, and it will be very difficult to strobe the timing mark in this condition as it will be covered by the timing tab.
Old Oct 14, 2009 | 12:15 PM
bc87corvette
Thank you all so much for your help. I really appreciate all your pics 86SPACER, it was very helpful. I now know exactly what you mean. I will check and keep you all informed. Thanks again.
Old Oct 14, 2009 | 05:44 PM
bomar76's Avatar
bomar76
Have been helping (via phone) a buddy chase a weird timing issue on one of his marine 454's.
Like a lot of people he came up with all sorts of off the wall causes and was very reluctant to actually check for a spun balancer.
Guess what the problem turned out to be?
Another spun balancer ring.
Old Oct 17, 2009 | 12:42 AM
pletzvet's Avatar
pletzvet
Originally Posted by joshwilson3
It sure is hard to get to that timing marking.
What brand harmonic balancers are you guys going with? On my 89 Firebird, I went with Damper Doctor as I heard good things of their rebuilt harmonic balancers.
I have heard complaints about the Dorman balancers. If I was to get one from Autozone, or one of those type of stores, I would get a Pioneer just because I've read a few things on the net that they are good and I haven't really found any complaints of them, but I have found many on the Dorman balancers.
I can't offer a whole lot of insight on Dorman except to tell you that I replaced the original HB with a Dorman (bought through NAPA) 3 years ago, It seems to be working fine, and holding together but I have know why of knowing whether it will last as long as the original one did (i.e. 22 years!)
Old Oct 17, 2009 | 12:44 AM
86PACER's Avatar
86PACER
I went with Dorman from Autozone, $50. Not a single issue with mine.
They have the puller and installer there too that you can rent.
