misses when accelerating - datamaster help
Old Sep 23, 2009 | 01:26 PM
tdr1919's Avatar
tdr1919
Default misses when accelerating - datamaster help
I have a miss when accellerating, sometimes pretty severe. I recorded about 15 minutes of driving using Datamaster. Can anyone tell me what relationships I should be paying attention to when trying to decifer this information?
Thanks,
Tom
Old Sep 23, 2009 | 02:39 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would check the plugs and wires first. If they're OK, see if the datamaster shows a lean condition.
Old Sep 23, 2009 | 03:53 PM
engle1147's Avatar
engle1147
Thanks,
Tom
Done any mods lately? Sounds like the air/fuel mix is off for whatever reason.
Old Sep 23, 2009 | 05:01 PM
JackDidley's Avatar
JackDidley
What year is the car ?
Old Sep 23, 2009 | 10:48 PM
tdr1919's Avatar
tdr1919
its an 86 manual, and i was determined to find out something, so i went out with my drop light and a can of throttle body cleaner. I recently upgraded with (FIC) Bosch II injectors, new fuel filter. I had this miss before I changed the injectors. So it really comes down to basics, if it sounds & acts like a vacuum leak them most likely its a vacuum leak. I started it up and sprayed the cleaner around the plenum, as I sprayed around the throttle body the RPM's increased.
I pulled off the throttle body and cleaned the mating surfaces I even replaced the gasket. Put it back together, started up, sprayed around the throttle body, only on the drivers side, rpms increased, I found a crack in the vacuum hose ( part of the crankcase ventilation) new hose
all good seems to have cured the miss on accelleration!
-Tom
Old Sep 24, 2009 | 10:27 AM
JackDidley's Avatar
JackDidley
If you email the datalog to me, I'll take a look at it.
Z666wright@yahoo.com
To misses when accelerating - datamaster help
