Clunking noise when engine is shut off
Old Sep 25, 2009 | 07:48 PM
Eric1994's Avatar
Eric1994
8th Gear
Default Clunking noise when engine is shut off
I get a intermittent clunking or banging noise after I turn the key off. The noise sounds like it is coming from under the hood. It will make noise for approximately 5 seconds. I tried opening the hood before I turned the key off but I haven't had any luck yet.
No maintenance has been performed lately. All gauges normal and car runs fine.
Old Sep 25, 2009 | 08:41 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Is the engine dieselling?
Old Sep 26, 2009 | 08:13 AM
Eric1994's Avatar
Eric1994
8th Gear
The engine runs normal and isn't dieselling, The clunking sound I believe is under the hood, but not in the engine.
Old Sep 26, 2009 | 08:49 AM
M. Schumacher's Avatar
M. Schumacher
Does it make the noise when you close the headlights?
Old Sep 26, 2009 | 12:48 PM
davidarnesen's Avatar
davidarnesen
is it more of a pinging noise?
Old Sep 28, 2009 | 09:29 PM
Eric1994's Avatar
Eric1994
8th Gear
I believe I found where the noise is coming from. I was cleaning the battery terminals and when I hooked up the negitive terminal the RH headlight motor started running. The light wasn't moving. I turned the headlights on and it opened normal except the motor ran about 5-10 seconds after the light fully opened and the same when the headlights were turned off. I'm guessing there must be some limit switches not working correctly or a sticky relay maybe.
Thanks for the help
To Clunking noise when engine is shut off
