AFR for LT1 install things to remember.
They are nothing spectacular, but they can be enough to **** someone off.
For example.
Gasket for intake manifolds to match. Which one for LT1 manifold and LT4 manifold
Oil drain up front, supposedly they are working it out, but until then the drain needs to be done.
Jim Masons valve cover issues with hold down bolts, needed to mill center bolts down.
Manifold bolts also dont go all the way through on some holes.
Is there anymore?
Regarding the intake ports, the best thing to do is get your intake port-matched to the heads and use the appropriate gasket. In my case, I already had a ported intake so had to do a little (very minor) gasket matching on the intake ports of the heads.
For example.
Is there anymore?
One of my pushrod holes did not align properly and the pushrod was too tight. We had to shave a little to get it right The new GM LS7 lifters were different but we were lucky that the original MTI pushrod length was a good fit. The new Ultra Pro Magnum Rockers fit with no problems.
Should fire it up and test drive later this week. Next drag race event is 10/18 so we will see how the new set up does. I also went with 42LBS injectors, 58TB and Lloyd Elliott ported LT1 intake. Moe Bailey, one of the top LT1 tuners, did the mail order tune. Dyno tune with him this winter.
Good to find out these little things prior to purchasing. I dont know Moe Bailey did tuning, link?.
For example.
Is there anymore?
You bought a set of AFR's?
AFR is selling intake gaskets that fit the port opening now so that problem is solved. Buy the recommended AFR PN Gasket and port match the intake to it, no problems.
It was a minor problem anyway as all I had to do was move the hold tab holes up .060 on a Fel Pro (stock LT4 gasket)... Fit the 195 Elims perfectly. The only thing anyone had a real problem with were LT4 intakes that had already been ported to the 777 "off road" gasket. The port is too tall on the roof to line up properly with the 195 Elims. I thought everyone knew you can't mix and match heads and intakes ported to different gasket specs and expect them to line up correctly.
Now the LT4 intake manifold itself is a problem. The top of the runners right at the gasket surface hit the wider valve cover gasket surface of the AFR heads... I had to grind about .150 off it to clear on Nolands engine. Pics and documentation are in his engine thread.
The drivers side front oil drain back is just flat drilled in the wrong place for a LTX block. Most engine builders don't even look becasue they don't bother to do any oil return work on their engines. If they did they would notice it is 100% blocked by the water pump bolt pad. AFR uses the same location as the GEN I SBC. This was a problem on the old AFR castings as well. Maybe they will fix it soon. If not it's short work with a die grinder to un-block it and your engine builder should be grinding to enlarge the oil returns anyway.
The one engine I built with a stock LT4 intake bolted up fine using the stock intake bolts, so maybe the intake bolts bottoming out is a prouduction varience thing.... my personal car with AFR210 elim's has a converted Super Victor so I have no idea whether they fit a stock intake or not.
I didn't have any problems with the AC brackets on mine or Nolands car. Nor the headers or exhaust system.
One other problem I had. The Comp port heads all use a 2.08 intake valve. That is bigger than most anyone else's aftermarket heads for the LTX. It can be very very tight on radial clearance with most off the shelf pistons. If you cam has a slow ramp it is probally not a problem (ie 234@.050 in Nolands engine = NO problems) but if your trying to make some real HP and the cam has a lot duration at .050 check carefully. I had to cut my first set of Wiseco pistons and the current Manley pistons for radial clearance on the intake valve reliefs.
Will
My shop guy said there was no blockage at all with the front oil drainback hole. My block was a MTI 396 LT1 shortblock built in 2001. Anybody have any thoughts why my front was not blocked?
