Lowering front end advice
Old Sep 29, 2009 | 11:54 AM
JUSBAD's Avatar
JUSBAD
Default Lowering front end advice
I have a 92 coupe that I want to lower, what is the consensus on the best way to do this, I have read many posts with different ways of doing this
Is it easier to use the wedges that are bought as a kit,
or
to just cut out the stock wedges
or
cut out stock wedges and the rubber pads at the ends of spring
or
anything else
I will post what my current measurements are when I get a chance, the rear is up on stands right now.
THANKS
Old Sep 29, 2009 | 12:01 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I used the kit and I'm happy with the results.
Old Sep 29, 2009 | 12:19 PM
mseven's Avatar
mseven
I did coilovers, it is not cost effective and will consume more time, but the results are being able to do whatever you want with height and shock control.
Old Sep 29, 2009 | 05:39 PM
Razor89's Avatar
Razor89
If money is not the issue. I went with Coilovers, 400 lbs springs and the QA1 dual adjustable shocks. I was able to lower the front by 1 1/2 inches without having problems with my steep driveway and the handling and ride quality is much improved. The back was just lowered with a longer spring bolt until I get the time and money to do the same to the rear.
Old Sep 29, 2009 | 07:17 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
how does the kit work and where can you get it?
Old Sep 29, 2009 | 07:46 PM
JUSBAD's Avatar
JUSBAD
Money will be an issue, so I need the cheap way of doing it for now.
Old Sep 29, 2009 | 08:54 PM
darkstallion_69's Avatar
darkstallion_69
all I did to mine was cut the sliders out and adjust the original bolt in the back. Depends on how low you want to go...or you can cut the sliders and put in the lowering wedges with the longer bolt to lower it a little more...
To Lowering front end advice
