Blown head gasket??
Old Sep 30, 2009 | 09:00 AM
subseawellhead's Avatar
subseawellhead
Default Blown head gasket??
Neighbor bought a C4 on craigslist and trying to help him out. The local shop claims it has a "cracked head gasket" but I want to see for myself.
The oil is clean and smells like oil, the coolant is full and smells like antifreeze, the car runs fine
How can I test for a blown head gasket??
Old Sep 30, 2009 | 09:23 AM
bomar76's Avatar
bomar76
1. Compression test
Old Sep 30, 2009 | 09:37 AM
subseawellhead
The shop says they did a compression test but if you have 1 cylinder low how do you determine head gasket versus rings or valves?
The C4 owner is not mechanically inclined at all,
Old Sep 30, 2009 | 09:40 AM
pr0zac's Avatar
pr0zac
pressurize the cooling system
Old Sep 30, 2009 | 09:43 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Definitive test is to test for disolved exhaust gasses in the coolant.
Seems to be a special order for the kit from the standard autoparts stores.
What year is the car?
What is it doing to make anyone suspect there is a problem?
Old Sep 30, 2009 | 09:44 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
And keep the pressure on for a few minutes at least, watching for any sign of dropping. Also you could watch the flow of water in the radiator, if there's a lot of bubbles then compression is getting into the system.
Old Sep 30, 2009 | 10:44 AM
subseawellhead
Thats what I was thinking
Thats what I asked the owner
I know we can get a pump to pressurize the coolant system to ?psi thru the radiator cap so if a leaking head gasket it will either push coolant outside the block or into the cylinder which we obviously don't want
Old Sep 30, 2009 | 11:30 AM
cumbercr's Avatar
cumbercr
What was the result of the compression test?
Old Sep 30, 2009 | 11:33 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Go to your local NAPA store and buy a block tester kit. You put the blue fluid in the plastic tube. Put the tube in place of the rad cap and run the prewarmed up engine. If the fluid turns green or yellow, there is exhaust gases in the coolent. It may take a couple of minutes, but this is the test I use.
Old Sep 30, 2009 | 11:51 AM
subseawellhead
You know how a shop is, they don't tell you #1@156, #2@165 etc
This sounds like the diffinitive answer
It's amazing how you can learn anything you need on the internet
Old Sep 30, 2009 | 12:33 PM
89onlyZ51's Avatar
89onlyZ51
only way to do it. Pressure testing the cooling system only tells you if you have a cooling system leak (15 psi). Combustion pressures are 1,000's of PSI. Get the NAPA block tester (balkamp 700-1006). It's very easy to use.
To Blown head gasket??
