700r4 TransGo install question
Old Feb 22, 2002 | 09:09 PM
Ingar, Norway's Avatar
Ingar, Norway
Default 700r4 TransGo install question
I'm a bit confused over the 4th accumulator modification and want to be sure I get this right.
As I understand the instructions the piston should be reversed and the supplied spring is installed between it and the case.
It's not mentioned what to do with the original spring (which is between piston and plate. Should it be left out?
(The TransGo might be a good kit, but that instruction sheet could have been more clear, does the company have any kind of internet support?)
[Modified by Ingar, Norway, 7:11 PM 2/22/2002]
Old Feb 22, 2002 | 09:53 PM
Bluevette85's Avatar
Bluevette85
Default Re: 700r4 TransGo install question (Ingar, Norway)
I have installed this in my 85. Install it just like the picture shows. The blue spring is used in Step 3 in my instructions.
Old Feb 23, 2002 | 01:18 PM
Ingar, Norway
Thanks! From what I can tell this will set the 3-4 accumulator out of service, but I guess that the intention.
Another "problem" I had was with the band servo. The instruction tells you to discard the locking spring, but if I do this my band is stuck. So I decided to use the lock-spring.
To 700r4 TransGo install question
