Nitrous kits
Old Oct 1, 2009 | 10:29 PM
lt1396corvette's Avatar
lt1396corvette
Default Nitrous kits
I used to run the NOS dry kit in my 94 vette 05176.I took it all off.I was going too install a supercharger,but changed my mind.I want too put another Nitrous kit on my car.What nitrous kits are you guy's using.I trying to figure out what kit too go with.Dry or Wet set-up.I liked the dry set-up but always hear good things about the wet set-up's
What are your opinions. thanks
Old Oct 2, 2009 | 11:35 AM
neat's Avatar
neat
Might want to check out the nitrous forum.
Old Oct 2, 2009 | 11:49 AM
pologreen1's Avatar
pologreen1
yeah check FI section or fo to DC vette because they have more and quicker replys to that type of stuff.(unfortunately)
Old Oct 2, 2009 | 02:42 PM
pr0zac's Avatar
pr0zac
nitrous express
Old Oct 2, 2009 | 04:26 PM
RacerX70CC's Avatar
RacerX70CC
My personal preference is for wet systems, based in part on my experience with them.
To me, the main drawback to a dry shot is that you're totally dependent on the ECM being "fooled" into adding more fuel when the system is activated, and you run the risk of not enough extra added fuel (which is how a nitrous system works - add the oxidizer and fuel to make power), being dependent on injector pulse width/duty cycle and injector capacity.
With a wet system, you tap off the rail directly, and add extra fuel with the fuel solenoid. Any "serious" nitrous kit is of the wet configuration - by that, I mean any shot over 150.
On my LT1, I ran a custom built (by my shop) wet plate setup:
- worked pretty well at 150 (using a Racetronix/Walbro pump setup and Aeromotive adjustable FPR)
more nitrous info can be found here: http://advancedautocc.com/page--Nitr...formation.html
Best of luck to you, whatever you decide...
Old Oct 2, 2009 | 08:25 PM
rickneworleansla's Avatar
rickneworleansla
Unless it's a Zex system which doesnt use the pcm or maf to add fuel. It does use the fuel injectors which you can go bigger on and a fuel booster pump that is included with the kit. At least there is no risk of fuel puddling in the intake.
Pros and Cons to both systems but if you want a serious nitrous setup with room for future growth then go wet.
There's a nice looking intake setup for sale on ebay right now but its for a 250 to 450 shot.
To Nitrous kits
