You have SR+195 and a 219,how long did you use that combo ?
oh its a 383 ...im 355 only
When mine was a 350 it would run 12.0s Now that its a 381 it goes 11.5
I can get more out of the car now by changing a few things. The heads i have are worked over AFR Racing version heads, The SR has been ported, the cam is what holding me back from going into the 10's That andsome skinnies up front and dropping the sway bar.
Things are good. But I want to make them better, my 219 cam is to small and I want to get down the track faster. The heads are worked over 195 100% versions and the suler ram has been ported by TEA. What cam should I go with to get this in the 10's?
