Spark Plugs???
P.S. What spark plug wires should I use?
Typically in a boosted application you want to go with "colder" plugs. spark plugs have a heat range, and boosted applications need a cooler spark plug than an NA combination.
NGK seems to be pretty popular for the boosted crowd. You can take a look at my signature for the exact spark plug that I am using.
You can also get a hold of Greg at blowerworks as he can sell you the correct set. Nearly anyone of these reputable corvette shops can also recommend a set.
