Stock crank question
Old Oct 4, 2009 | 09:13 AM
Sliding's Avatar
Sliding
Default Stock crank question
How are journals on stock vette crank finished?
Is that just raw casting machined to dimensions or
are journals hardened in some way?
Old Oct 4, 2009 | 09:26 AM
engle1147's Avatar
engle1147
Raw material is just machined then polished. If you want a stronger crank go with a forged product. The bearings are softer than the crank material...using non-technically speak on a properly machined jornals there should be an oil "cushion" in-between the contact points.
Old Oct 4, 2009 | 12:39 PM
Sliding's Avatar
Sliding
OK, thanks! I ask because some european engines have stock cranks that are nitrited and if they are machined they are very soft under that thin coating.
Old Oct 4, 2009 | 08:31 PM
JAKE's Avatar
JAKE
You'd have to do some research to see which of GM's cranks received this hardening process. Some did, but I don't recall which ones or which year cranks received it.
I do recall reading about certain processes GM uses to harden the journals and at least one company (probably more) still offers it. I saw it advertised in one of the mags.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
To Stock crank question
