Headers for 96 LT1
install a set of HEADERS..
need a lil help thou, to many options..im not racing this car or ever will
but i want some extra hp..ill be installing a lil cam as well..
QUESTION : what would be the best choice for street headers that
would be practical.?LONG, Short, any prefrence? THIS IS A DAILY DRIVER.. all advice welcomed...and any other way of ez hp..ALSO how big a cam can i go before affecting vacum..
Alot of people here believe shorties are not worth the time , money or effort.
I say this and I currently have a set of hooker shorties on my car. Was there any HP gain when I installed them? Dunno, Its hard to tell because we did alot of other work at the same time.
I did buy a set of Exotic Muscle long tubes (they just got delivered this week) I will be replacing the shorties with the long tubes when the fresh motor goes in the car in a month or so.
thanks for your advice on headers
new gears in the near future around 3.73
I retained the stock lt1 exhaust because its fairly nonrestrictive at my hp rating and I wanted to invest the $$ in the headers & cam rather in a corsa exhaust.
I am VERY happy with not only the performance but also the sound. The LTs give it a much deeper richer sound with absolutley no resonance whatsoever
-back on topic-
the Long tube headers are definitely the direction to go, however, it looks like ZR1WANNABE might be getting rid of his shorties for fairly cheap. If you're not certain which one you want to go with, why not buy the shorties off of him and try them out?
or course in my opinion it's best to do it right the first time (long tubes).
I believe it will me MUCH more critical to focus on primary sizes at this point rather than cosidering shorties.
I.e. 1 5/8", 1 3/4", 1 7/8", the larger tubing will hurt bottom-end, so I'd say stick with whatever complements the head work and cam.
Hooker seems to be a relatively affordable set of headers to go with
TPIs
EM
Melrose
Stainless Steel Headers
etc.
-back on topic-
TPIs
EM
Melrose
etc.
It appears that long tubes are the way to go...im not racing it, I just want to know that i have some extra ump when i step on it..
The cam I used is a LE 226/230 .565/.565 111 lsa. I'm very pleased with it so far. Plenty of vacuum for the brakes. Haven't tried the AC yet.
Thanks,
93 cruiser
You have to take off the exhaust manifolds, naturally. On the drivers side you'll have to remove the alternator to do that. Plus swing the ASR out of the way. Most likely remove the spark plugs. The bolts on the exhaust flanges can be difficult if they have been removed in a while. The starter may have to be removed but it will fit back usually with no problem. There is just about always some exhaust pipe work needed to mate up with the rest of the system. You may have O2 bungs to deal with. The '96 has 4 O2 sensors and most headers for them only have 3 so a bung will have to be welded in or the PCM retuned to tune the rear ones out. There is of coarse the cats to deal with. Usually a couple of bullet cats work really well.
As you can see it's not just a simple bolt on. If you don't have a decent set of tools and basic mechanical knowledge it might be kind of rough.
There are a ton of header threads on here. It would be worth your while to read up on several.
Good luck and have fun if you decide to get them. It is worth it though!
