Fuel Injectors Question
http://forums.corvetteforum.com/c4-t...-problems.html
After I took the injectors off on my 84 to clean them and I put them back the car would not start. I would pour fuel down the throat and it would start. So I had someone else try to turn on the car while I watched the injectors. I noticed the passenger injector only dribbled when before it would spray. The driver injector would not even leak dribble or anything when before it too would spray. I took off the injectors and the holders were wet with fuel, so fuel is getting upto the injectors just not pass them.
Is it possible I that I switched the injectors and that's causing the problems. I didn't know that each injector had a designated place, is this true? You can see fuel and bubbles in the screen on the injector.
What is the spring for in the holders?
I appreciate any help.
