Brakes!
Old Oct 15, 2009 | 11:07 AM
josephf31's Avatar
josephf31
Default Hvac
Originally Posted by Phantom_Vette1
Yeah it is good to go over the whole engine bay(especially when i am new this car) you find all sorts of things! lol
I saw that t-piece that connects to the vacuum tank!
What is a HVAC?
Thanks!
is your climate control -- Heating Ventilation Air Conditioning
Old Oct 15, 2009 | 08:24 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
It is easy to pull most of the ABS fault codes using a paper clip bent into a "U" shape.
With the ignition off -Insert the paper clip into the "H" and "A" pins of the ALDL (usually located at the bottom of the left dash above your right foot).
Turn the ignition "on". A flash sequence should appear on the dash (speedometer).
The flash sequence will begin with a Code 12 to signal the beginning of the fault code display. Each stored code will be displayed three times. After all of the codes have been displayed, the sequence will repeat starting again with Code 12.
Example: Code 12 = one flash then two flashes.
Rather than typing in all of the codes and their definitions, if you get any codes post them here.
There are five codes of the eighteen possibilities that are NOT readable by this method. You will need someone with a GM "Tech 1" code reader to retrieve those five. Any GM dealer should have a "Tech 1" reader-most independent shops don't.
Old Oct 15, 2009 | 08:39 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by runner140*
The short answer:
1. A hissing while braking or a hard brake = you need a new brake booster.
2. Taking a drive to charge up the battery? Thats a good way to burn out an alternator. Use a battery charger or a trickle charger, its a better way to go.
Good info
Old Oct 15, 2009 | 09:59 PM
Phantom_Vette1's Avatar
Phantom_Vette1
Josephf31: thank
Wildride: thanks, is that for a 90 model? i have heard that they changed for 92 up?
I wonder whether other car brake systems can be adapted to fit the vette? the only reason i ask, is for me to buy a booster they are AUD $400+ (being in Australia) but if i used a more modern one with master and all(from our commodores) i could get it all for probably AUD $100 and most likely have a lot better braking! As i have said before my other car will stop straight away as i touch the pedal, whereas the vette needs quite a bit of pedal before it even starts to slow! just wondering?
Old Oct 16, 2009 | 09:52 AM
Wildride's Avatar
Wildride
You wrote:
"Wildride: thanks, is that for a 90 model? i have heard that they changed for 92 up?"
Those ABS Code instructions are for a 1990. Other years I don't know.
If your car has been converted to right hand driving the ALDL socket may have been moved. Having never seen a RHD conversion in the states, I don't know about that one!
Old Oct 17, 2009 | 01:04 PM
Phantom_Vette1
Ok thanks for the code retrieval help!
No my vette is still LHD, i wanted it as it came
