Brakes!
I took my 90 out for a drive to try and get the battery charged up but it seems it is not taking a charge! so looks like new battery there!
anyway
while braking i noticed a sort of air noise(escaping), Could this be the booster?
I have been disappointed with the brakes since i bought it 6 months ago, but just thought it was how they were! but now thinking it could be the booster! the pedal had 1/3 travel before it starts to brake and the force needed is harder than it should be and doesn't stop very quickly unless really pushing the pedal.
The ABS needs servicing too, but this shouldn't effect the normal brakes operation, right?
thanks
What do you mean be ABS need servicing. Under normal circumstances they don’t need routine servicing. If you don’t think its working at all then it need repair. Why do you think it is bad, what are the symptoms. And also, if the brakes are not working right, you will never get the ABS the kick in on a road (maybe dirt or gravel).
1. A hissing while braking or a hard brake = you need a new brake booster.
2. Taking a drive to charge up the battery? Thats a good way to burn out an alternator. Use a battery charger or a trickle charger, its a better way to go.
We have a service in Perth that come out to you when in need of a jump start or what have you! and every other time i have had my engine(other cars) jump started they say go for a 30 min drive to charge it up! i don't see how it could burn the alternator out, it's not working any harder than normal! That's what the alternator is for, to keep the battery charged? right!
Anyway thanks for the response!
The ABS service soon light comes on as soon as i start it up and stays on!
Also i have locked up the left rear while testing for the ABS!
the brakes work but need a harder pedal force to brake like they should with less effort! i had to really press the brakes full on to get it to lock!
I have a 98 Holden Commodore which of course will have better brakes anyway(newer car) but it also has twin piston brakes etc...
and they only need a touch of the pedal before they bite!
thanks
Brakes - sounds like a booster to me. When you replace it do a FULL brake system flush.
Check the abs sensors to make sure they are all in place and not covered with road junk.
I think on the 90 you can hear the abs pump either on startup or as you approach 5mph. The FSM will have the details.
I need a FSM they can be bought on ebay right?
Do booster's commonly go on these c4's?
With the ABS i looked at the left rear brakes once, but weren't too sure where the abs connection was, i saw two parts it could have been! is it the part closest to the disc? with the wire?
The only noise i hear is the fuel pump priming and then the v8 roar!
probably not the ABS as it isn't working!Yes i agree parts that concern safety should be replaced, but i bought this c4 thinking that it was in good condition, but having to fix the heater core, the under seat transmission, flushing the radiator and new coolant/water, new battery, spark plugs, hood release cable, i just haven't the money just yet! but it will be next on the list!
I am in Perth W.A. so it doesn't get stored anytime of the year!
i also have smelt some oil burning after idling for awhile! is this the intake manifold gasket? or most likely?
If no leaks(oil) are found, it may be burning oil.Burning oil overtime will damage catalytic converters & spark plugs.I hope this helps
As i live in Western Australia there is only a couple of shops that work with American cars! I will probably have to see them about my ABS and would have the tech to gets codes!, although most reputable shops should be able to handle any ABS systems! they would be very similar to our cars i would think!..... but i will see!
Apparently the air con system( which needs gas) is very similar to our VN commodore 89-93 model, so it seems the similar years use pretty much the same setups! From your GM to our GMH dealerships!
anyway back on topic!
yes i do need to get those codes! i might try it myself, the paper clip method!
with the ABS connection, how do i get the wire off? does it unscrew or is a wrench needed? thanks
oh i tested the brake pedal(engine off) after running the car, and it only takes 1 and a bit pushes until it is hard! so i am guessing a leak somewhere!
i can hear the noise coming from under the dash near brake pedal-to-booster!
i can hear the noise coming from under the dash near brake pedal-to-booster!It's the round plastic 'ball' in the front left corner of the engine bay (on my '91).
It's supposed to 'hold' vacuum when the engine is not running for things like the HVAC etc. not sure if it's connected to the power brake booster or not...just a thought...
The low speed charging capability s more important than the maximum amps anyway.
To change out the alternator, you have to file out the top bracket and ream out the battery lead that fits on the back of the alternator.
but i did find that the line going to the cruise control was so deteriorated, the hose was flat. so that needs replacing
Well you found some old hoses so it wasn't a complete waste of time LOL
I saw that t-piece that connects to the vacuum tank!
What is a HVAC?
Thanks!
