Teach me how to port a plenum
Old Oct 6, 2009 | 03:34 PM
powerpigz-51's Avatar
powerpigz-51
Originally Posted by Pwnage1337
Is that a stock base? Or a bigmouth? Edit: just read the thread, its a stocker.
This makes me want to break out the die grinder and start porting again..even though when I am porting I hate it.
Thanks Rodj......good reading.....I am now convinced I need better heads. My stock heads are fresh, so I may consider doing some light porting on them. I just read a old article in Chevy High Performance magazine on how unshrouding the valves and some bowl porting under the seats can be of benefit. I also want to lose the exhaust valve rotators by shimming the springs. I am thinking that siamesing my eddy base and max porting some SLP's may be in order. I am currently running a Summit TPI cam with .420 intake .442 exhaust lift. Some 1.6 rockers on the exhaust side, and I should be good to go until the time comes for new heads, cam and some long tube headers. The search is on now for some used SLP's.
Old Oct 6, 2009 | 04:36 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Originally Posted by 94vettelover2
I recommend any color besides black because black attracts heat.I also heard of people painting underside of intake white because white reflects heat.
Most intakes don't sit out in the sun.
Old Oct 6, 2009 | 05:16 PM
ekess744's Avatar
ekess744
Old Oct 6, 2009 | 05:50 PM
rodj's Avatar
rodj
Originally Posted by blakngold4life
does anyone have info on temps going up when painted black? .
Underhood temps on a C4 are so high no amount of paint is going to have any effect once temps stabilise. As noted if your intake was sitting out in the sun it would be different.
Old Oct 6, 2009 | 05:52 PM
94vettelover2's Avatar
94vettelover2
They do when the hood is open
Seriously though,on Hosepower tv they said that some engine performance engine builders do paint underside of intake to possibly lower intake temps.Whether this is true i'm not sure.
Come on surfnsun,don't the lt-4 intake look alot better than the black one on my lt-1?Also I believe if GM made their intakes white they would stain & get dirty/ugly quickly.I do some research & see if painting something black will cause it to stay/keep heat longer.I think its hotter in my car(all black interior) than a white or beige interior when its sunny/hot outside.I heard growing up that black cars are hotter inside & paint attracts more heat.If this information is incorrect,set me straight.
Old Oct 6, 2009 | 06:04 PM
mseven's Avatar
mseven
I suppose the use of ceramics or thermal barrier coatings could be constrewed as a type of paint.
Also I believe if GM made their intakes white they would stain & get dirty/ugly quickly. I do some research & see if painting something black will cause it to stay/keep heat longer.
I see no ill effects due to engine color regarding operating temps of the motor......maybe I'll have to paint mine white..
Old Oct 6, 2009 | 06:05 PM
rodj's Avatar
rodj
They do when the hood is open Hosepower tv they said that some engine performance engine builders do paint underside of intake to possibly lower intake temps.
I don't drive with my hood up.
The best mod for the underside of a intake is a deep splash shield; stops the hot oil transfering heat to the intake.
That is why the latest trend in engines is to have a valley cover and the intake seperate so as to reduce heat transfer to the incoming air like on the LSX engines
Old Oct 6, 2009 | 06:21 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
\Whether this is true i'm not sure.
Its not true.
They don't paint them white b/c it doesn't matter.
The reason black cars get hot is b/c black absorbs all of the colors in the visible light spectrum while white reflects all colors of visible light. When your hood is down everything is black as there is no light.
Paint your intake whatever color you want but don't do it for performance as you won't get any.
Go back and study they types of heat transfer convection, conduction, and radiation.
Old Oct 6, 2009 | 06:39 PM
94vettelover2
Its not true.
You are right.I did some research & black intakes can help engine run cooler although,some aircraft engine sites claim painting engine brackets can help engine run cooler-thats what I got from it.
Heres the site tell me what you get from this info-http://www.avweb.com/news/maint/182886-1
By the way I don't believe everything I find on the internet & if I'm not sure about something I will admit it.I'll never claim to know everything.
Thats why I'm here-to learn & share to my knowledge
Old Oct 6, 2009 | 09:10 PM
ch@0s's Avatar
ch@0s
Here is what I did to mine before I went HSR using a die grinder and egg shaped bit. NOTE:The runners are SLP
I also used goggles ear plugs and mask, the shavings go everywhere you don't want to add a Docs appointment to the cost off the mod.
Old Oct 6, 2009 | 09:46 PM
rodj's Avatar
rodj
Nice
Be sure to get a carbide bit for Alum ( coarser ) not steel or you will be forever cleaning it as it clogs up
Old Oct 6, 2009 | 10:57 PM
Bobwhite85's Avatar
Bobwhite85
Originally Posted by ~Oakley~
I have a 1986 Early style Corvette. I just purchased a plenum from a 85 corvette. I am going to have one professionally ported by corvette plenum but am going to try to teach myself on the other plenum. What tools do I need and how do I go about doing it. Thanks in advance.
This is my porting tools. I have found a use for just about all of them. I have even bought more bits and sanding barrels since I took these pics. More pics to come
bob
Old Oct 6, 2009 | 11:13 PM
  #33
Bobwhite85's Avatar
Bobwhite85
Default Porting tools
The Bit I'm pointing at is the one I use the most. If you can get ahold of "crusinartvette" here on the forum, you might be able to get some pointers from him. He is, by far, one of best in the field. IMO! Good luck with your porting job.
Bob
Old Oct 7, 2009 | 02:55 AM
  #34
pologreen1's Avatar
pologreen1
I bought 2 $3 bits, 1 cone, and 1 oval, it took me about 10 minutes to buzz through each port hole on my stock one, I did not even have to oil them, they ripped through and was pretty smooth I just used some fine paper to finish it. With the right tools it can be done in no time. I would cut most out with a wheel or a blade then clean the rest with bits.
Old Oct 7, 2009 | 12:23 PM
  #35
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by nutz4c4
Old Oct 7, 2009 | 05:17 PM
  #36
ekess744's Avatar
ekess744
Bob
the carbide bits you have are for steel, not aluminum
Old Oct 7, 2009 | 06:25 PM
  #37
Bobwhite85's Avatar
Bobwhite85
Yes, you are correct. I have found that the steel bits work better for me, as they don't remove alumi material as fast as the alumi bits. They also leave a smoother finish (IMO). I'm new to the porting field and need all the extra help I can get Here is some pics of a set of LT1 heads for my stroker build, that I ported with the bits in the pics.
Bob
To Teach me how to port a plenum
Old Oct 7, 2009 | 07:15 PM
  #38
ekess744's Avatar
ekess744
I think it's best to use the alum first, then step down to the steel. I did use some steel bits on my 113 heads, but I had a lot more material to remove due to the larger valve I had put in
Old Oct 25, 2009 | 01:32 PM
  #39
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I just took a grinder and sanded down all the humps inside the plenum and the large hump right behind the throttle body it till it was flat. Im kind of scared this might hurt the car since its changing the air/fuel ratio in there since theres no more humps. Umm, did I mess up because that was way to easy....
Old Oct 26, 2009 | 08:33 AM
  #40
HlhnEast's Avatar
HlhnEast
I dunno, I aint no scientist but seems to me heat absorption of colors has to do with light, not temperature. You know, when ya wear a black Tshirt you feel hotter than when ya wear a white one? Since this idea occurs under the hood, it shouldnt matter. If ya like the painted look by all means paint away but if it does work, it would be so small a difference you couldnt measure it. It would also seem that if you go coating your components on the outside it would serve as an insulator keeping the heat in. Just my .02, Ive been wrong before, lol.
