91 vette/ TPS voltage
Old Oct 5, 2009 | 07:19 PM
shiyfire's Avatar
shiyfire
Default 91 vette/ TPS voltage
I was checking my sensors with my scan tool today and my TPS read .7 v . I had to enlarge the sensor adjustment holes to get it down to .5v . I had a lopey up and down idle before and this seemed to help smooth it out a bit.My IAC motor is hanging around 45 now ,it was staying in the 50's .I would like to change the injectors soon to smooth it out a bit more.Will i have to drive it a while for the other sensors to adjust to the change i made on the TPS?
Old Oct 5, 2009 | 07:24 PM
rodj's Avatar
rodj
TPS on yours is not adjustable.
The ECM takes the base figure it first sees and uses that as the idle setting
