injectors
Old Oct 6, 2009 | 12:30 PM
Ray85Vette's Avatar
Ray85Vette
Default injectors
how do you check your injectors on 85 vette. any help would be appreciated. thanks.
Old Oct 6, 2009 | 12:45 PM
aklim's Avatar
aklim
IMO, you don't. If you want to see it spray, take it off and have someone crank the car. That gives you a rough idea. Other than that, I think it is best of you took them off and sent them to FIC and have John look at it for you. The have ways to see the spray pattern and, more importantly, check the flow rates. I would not recommend that you deal with pressurized fuel. I have done what I suggested for diesel and if you want to do gas, make sure it is in a very ventilated area.
If you do that, remember that smoking WILL BE bad for your health.
Old Oct 6, 2009 | 12:53 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You can measure the resistance with an ohm meter. Should be around 16 ohms.
Old Oct 6, 2009 | 01:07 PM
pcolt94's Avatar
pcolt94
That is definitely a good start. But that does not insure the valve is working or spraying correctly. A lower resistance say 8 or 10 ohms is a give away the injector coil has a problem and probably not working correctly.
Old Oct 6, 2009 | 01:14 PM
aklim's Avatar
aklim
For a car that old, it is very likely to have varnish in it. There are all kinds of things and the ohm test is only good to ensure that one part is working properly. R&R with a test bench is the best way to know if it is spraying well or not.
Old Oct 6, 2009 | 01:51 PM
89onlyZ51's Avatar
89onlyZ51
You can do that, but coil shorting is not a problem on the '85's bosch injectors. As others said, you have to check the spray pattern and volume - best left to the pros.
Old Oct 6, 2009 | 02:36 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If ohm reading is in spec, and fuel pressure is good, how does it run? If it idles well and revs smoothly to WOT, chances are you are good.
Old Oct 7, 2009 | 01:08 PM
josephf31's Avatar
josephf31
Default It's a lot less work
to ohm the injectors first and see if any coils are bad, before pulling them, which is a way bigger job.
Old Oct 7, 2009 | 01:13 PM
aklim's Avatar
aklim
You cannot detect changes in the injector flow. Those happen over time. So even if you ohm it and it does all you say, you will not really know if the spray pattern is good or the volume sprayed is constant.
Old Oct 7, 2009 | 01:49 PM
megtom2's Avatar
megtom2
How much do they charge to test spray them? For $150 just replace them all after going through the hassle of removing them.
Old Oct 8, 2009 | 10:24 AM
josephf31's Avatar
josephf31
Default Good point
Old Oct 8, 2009 | 01:39 PM
Bad Karma's Avatar
Bad Karma
Look at the sticky up top for injectors it's got real good info. I think everybody here covered the rest.
To injectors
