Cam / LT1 how big ?
Old Oct 6, 2009 | 10:53 PM
ol school's Avatar
ol school
Default Cam / LT1 how big ?
96 LT1
Heads are off gettin some work,and installing LT 1 5/8 headers i want to put a cam in...
Now as a DD with all the luxury's ,and stock heads (for now)How big a cam will work with a/c and power brakes?
Old Oct 6, 2009 | 11:07 PM
96GS#007's Avatar
96GS#007
Originally Posted by ol school
96 LT1
You need to define power goals and future mods. Just putting a big cam may get you nothing.
You need to figure out what valve springs you're going to use as well. The stock ones aren't even safe to use with the LT4 HOT Cam which is 218/228 @ .050 and .525/.525 lift.
FWIW, my cam is 230/236 @ .050, .622/.624 lift and could easily be driven every day. My A/C and power brakes work perfectly.
Old Oct 7, 2009 | 12:48 AM
92ZR1WANNABE's Avatar
92ZR1WANNABE
Not sure if its legal to link to another forum but i'll give it a try.
http://www.ls1tech.com/forums/lt1-lt...ion-guide.html
Lots of good info.
I currently have a CC305 getting ready to go into a 355.
Old Oct 7, 2009 | 12:10 PM
ol school's Avatar
ol school
what are you running for heads
Old Oct 7, 2009 | 03:55 PM
96GS#007's Avatar
96GS#007
AFR 195 Eliminators with their competition porting and springs good to .650 lift.
Old Oct 7, 2009 | 04:25 PM
93 ragtop's Avatar
93 ragtop
IMO the hotcam is an excellent choice especially if you are not reworking the bottom end.
I would not try to spin the stock bottom end above 6200-6300 rpms if you want it to stay together and with a bigger cam, you are going to be temped to do that and may very well have to to make more power then the hotcam will give you.
Myself and a few others have ran in the mid to high 11's with the hotcam, and to be honest, im not seeing any better on a stock bottom end motor.
It can be tuned to pass emissions and the price cant be beat!!
Old Oct 7, 2009 | 06:27 PM
rickneworleansla's Avatar
rickneworleansla
My cam specs..
226/234 Duration, 565/565 Lift, 109 LSA
Non-emissions cam. Brakes and AC work fine. I spin it to 6500 and occasionally spray a 125 shot on the stock bottom end.
Old Oct 7, 2009 | 06:42 PM
93 ragtop's Avatar
93 ragtop
Originally Posted by rickreeves1
My cam specs..
Good luck!! I hope it stays together. Alot of them dont. Especially with the nitrous.
TLS_Addict's Avatar
TLS_Addict
I thought the hot cam was only .525 if you changed the stock rocker arms.
I was under the impression that in order to get that lift in the LT1 you had to upgrade the rockers. Also, that is pretty "cheap" on GMs part if a stock spring wont take .525 lift.
Old Oct 7, 2009 | 06:48 PM
pr0zac's Avatar
pr0zac
there are plenty of stock bottom end cars running heads, cam and nitrous..
Old Oct 7, 2009 | 06:49 PM
pr0zac's Avatar
pr0zac
well considering stock is .450 lift i am thinking .525 is quite a stretch.
Old Oct 7, 2009 | 07:27 PM
ol school's Avatar
ol school
Lots of good info.
GOOD LINK, pretty informative, thanks
Old Oct 7, 2009 | 07:30 PM
ol school's Avatar
ol school
okay , I Have to ask I Keep hearing the phrase "hot cam" what does mean..
Old Oct 7, 2009 | 08:09 PM
pr0zac's Avatar
pr0zac
GM's lt4 hot cam. 218/228 .525/.525 on a 112lsa
Old Oct 7, 2009 | 08:10 PM
aboatguy's Avatar
aboatguy
You settled for too small
Just kidding
http://www.summitracing.com/parts/NAL-12480002
I have a 355 and went with a 23x 23x on a 110LSA with .615 lift
My oldest daughter used to drive it to high school every now and again. before she graduated so it is extremely streetable and reliable. Now some of the other parts are not so durable behind it (torque converters, tranny etc) but engine has been SOLID.
Mike
Old Oct 7, 2009 | 09:28 PM
95wht6spd's Avatar
95wht6spd
Remember he has an auto too, so you will need to change stall/gears etc. if you go very big.
Old Oct 7, 2009 | 09:52 PM
ol school's Avatar
ol school
is this a factory cam ? or a hotter then stock for the LT4 and i guess since its a sb it'll work in my LT1
To Cam / LT1 how big ?
Old Oct 7, 2009 | 10:25 PM
93 ragtop's Avatar
93 ragtop
It is a factory cam, but was not built for production use. It was designed for the LT4 for racing. It was not designed to pass emissions etc, but with tuning it will.
Old Oct 7, 2009 | 10:28 PM
93 ragtop's Avatar
93 ragtop
Heads and cam, yes. Nitrous, yes some, but the factory pistons will not take much abuse. I noticed in your profile you have forged pistons.
Old Oct 7, 2009 | 11:26 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Well the nice thing about buying the Hot Cam Kit is that it comes with upgraded rockers, springs,etc. I've had it on my 95A4 for the past 30,000 miles and really like it.
