C4 LS swap a different perspective
Old Dec 23, 2019 | 05:39 PM
  #141
JoeNova's Avatar
JoeNova
Originally Posted by Joshie225
Cool. How do I, for pennies, feed the Gen III PCM OBD II engine data to my 8192 baud CCM so that my original gauges work? I don't want to toss the original gauges because a lot of vehicle diagnostic information is displayed there. And I do use that data. I recently diagnosed a no-crank condition using the CCM diagnostic mode.
That CCM data is literally decades behind your average $0.99 smart phone OBD-II app.
You've already talked yourself out of the swap. Move on.
Old Dec 23, 2019 | 05:45 PM
  #142
Joshie225's Avatar
Joshie225
Originally Posted by Krusty84
I think the gauge cluster and A/C issues are just excuses for a lot of these guys because they hate the LS swap idea in general.
If you install an LS, the car becomes unoriginal so what difference does it really make if you install an aftermarket gauge cluster?
I can understand folks not wanting to hack the K-member for the C5 A/C compressor location as there really is no reversal of that, but not wanting to do a swap because you can't use 24-30 year old gauges seems like a weak argument to me.
I don't hate the LSx engine at all. In fact I would love to ditch my OptiSpark. I bought my '94 for $4k and all it really needed was tires and rear shocks. Originality doesn't mean much, but functionality does. An aftermarket gauge cluster won't display CCM diagnostic information. The CCM is the nerve center of a late C4. ASR, ABS, PKE, climate control and engine data all flow through the CCM and the diagnostic information is displayed in the speedometer area of the instrument panel. How do I keep my diagnostic information with an LSx swap?
Old Dec 23, 2019 | 05:46 PM
  #143
Joshie225's Avatar
Joshie225
I'm asking for solutions. Do you have any?
Old Dec 23, 2019 | 06:21 PM
  #144
DMITTZ's Avatar
DMITTZ
In my comment I was referring to the gauges in the Pre 1990 C4's. The later C4's are more complicated. However I'm quite sure it can be done. I've Done a fair bit of reading/ research in preparation to LS swap my 88' and I have some threads/articles bookmarked Where later C4's had LS swaps completed:
I think this one was a 1992...
https://ls1tech.com/forums/conversio...-t56-swap.html
I think this one is a 1991...
https://ls1tech.com/forums/conversio...my-swap-2.html
And another 1991 swap....
https://lsswap.parts/1991-corvette-c4-ls3-tr6060-swap/
You'll have to spend the time to read through these threads as I don't remember What page number talked about the dash etc....But if your considering an LS swap then it will be time Well spent.
2 of the threads linked above are by corvette forum members that still respond to PM's so any questions you have after reading the threads they can proabbly answer for you.
Best of Luck!
Old Dec 23, 2019 | 08:04 PM
  #145
84 4+3's Avatar
84 4+3
See below for option 1.
And I didn't say the factory gauges. They're ****. Ditch them. If you're hacking the thing up to get it in there originality is of least concern.
Old Dec 24, 2019 | 10:17 AM
  #146
JoeNova's Avatar
JoeNova
I use a tablet for my gauges.
I have FAR more gauge options than the factory cluster as well as being able to design my own layouts and view custom sensors, all of my music pre-loaded as well as satellite radio, GPS navigation, GPS datalogging, ECU datalogging, check-engine light diagnosis, heads-up display capability, touch-screen functionality, built in acceleromoter, cameras, GPS tracking if it gets stolen, I could go on and on.
Ditch the factory crap cluster, wire your interior to operate independently of the CCM. Stop letting the factory cluster keep your car from being a considerably more enjoyable experience. The End.
Old Dec 24, 2019 | 10:40 AM
  #147
DMITTZ's Avatar
DMITTZ
As I had referenced in my earlier comments I'm pretty sure you can make the stock gauges work on a late C4 with LS swap....
But here is another option that looks pretty sharp if you want to ditch the factory gauges...
http://vettaid.com/dash-kits-for-the...996-corvettes/
Hope that helps....
Old Dec 24, 2019 | 11:31 AM
  #148
Joshie225's Avatar
Joshie225
I know what I can do with OBD-II and a tablet. Here are the 6 pages of wiring diagram to show you what goes through the CCM on a '94 so you can work up a bid for rewiring my car and not losing any functionality.
Old Dec 24, 2019 | 11:38 AM
  #149
Joshie225's Avatar
Joshie225
Best of Luck!
Thank you, I am now digging into the first thread. Also, since my post on 12/15 regarding working with the LT1 in my '94 to meet my modest power goals I have bought a '93 with a built engine so the '94 is likely to stay stock. If I want to pursue LS power I'll use the '93 as it's a base car while my '94 is a well optioned Z07 package car.
Edit: I read through the first thread. He's using a Gen 4 PCM and has had VSS problems that are not present with the Gen 3 PCM. He also spent a ton of money which is antithetical to the whole "Cheap LS Power" ethos. I have to go do a little work for my job today so the other threads will have to wait.
Old Dec 24, 2019 | 11:43 AM
  #150
JoeNova's Avatar
JoeNova
Do you have a list of inputs that the CCM needs from the ECU? That would be a start. Everything I see on every page is something that the Gen 3 PCMs all have outputs for.
Old Dec 24, 2019 | 11:48 AM
  #151
Joshie225's Avatar
Joshie225
The '94 PCM passes data over the ALDL serial bus to the CCM. That's E13/F12 Serial Data on page 6. That's where this whole mess breaks down. Torqhead have a solution for this, but I haven't gotten a response from them. I will try again in the new year.
Old Dec 24, 2019 | 01:00 PM
  #152
84 4+3's Avatar
84 4+3
you may, note may, be able to hack the gen 3 serial output and modify the coding to interface with the CCM data stream. However you would need someone who is exceptionally better at coding than I am. But I have seen instances where people go that far into the ecm.
The other alternative is hacking the LT1 ecm to work with the LS but I'd feel that would be next to impossible to have working correctly. The reluctor wheel for the ls crank being the biggest issue I see. You can get around drive by wire and the rest of the sensors however. The later LT1s ran sequential injection so that isn't an issue... this is actually really interesting. Since people do 411 swaps into C/K trucks it may be able to be done...
Old Dec 24, 2019 | 01:19 PM
  #153
Joshie225's Avatar
Joshie225
You understand the problem! Torqhead has figured this out for '94-'96 cars as he's running them with 0411 PCMs and his 24x hardware. I want to know if I can buy his services to do exactly this kind of serial translation, but run an LS engine which wouldn't need any of his 24x hardware.
I had considered running an LS engine with the LT1 PCM, but the LT1 OptiSpark position information wouldn't be there so there would need to be a box to synthesize that from the 24/58x signals. On the surface this seems far easier that translating Gen 3 PCM data to satisfy the CCM and all the interconnected systems. Of course this gives up having a modern PCM, but the rest of the car stays working. If Torqhead will support C4 LSx swaps then we get better engine hardware, a better PCM and a fully functional late C4 Corvette.
Old Dec 24, 2019 | 06:09 PM
  #154
DMITTZ's Avatar
DMITTZ
Your Welcome, I don't have all the answers as my car is an early C4 but if nothing else it will be an interesting read.
Ya I know you can do a 'Cheap' LS swap and some have accomolished it (at least on early cars)... But ya to do it right gets expensive, at least my swap is getting pretty expensive, but then again a lot of stuff I just choose to do for fun vs need to spend money to make it work. Mine will be similar in cost and scope to the first thread when its all said and done.
For sure if your happy with the output and manners of a modified LTX engine then leave it be. I've had my C4 for 16 years, its had a stock engine, cammed engine, built SR engine etc... so I just want to take it in a new direction doing the LS swap, cause I get bored... and building something is more fun to me than just buying a C6 or C6Z06. But that's just me.
