reinstalling heads
Old Oct 9, 2009 | 12:42 PM
ol school's Avatar
ol school
Default reinstalling heads
QUESTION !
Im reinstalling my heads this weekend, IS IT REQUIRED TO REPLACE THE ORIGINAL HEAD BOLTS??
Old Oct 9, 2009 | 01:12 PM
CFI-EFI's Avatar
CFI-EFI
Historically, no. Some of the newer engines with "Torque To Yield" (TTY) head bolts should be changed every time they are torqued. Not so with a conventional Gen I, or Gen II, SBC engine. The factory SBC head bolts are good for several reuses. If you feel them stretch or they feel spongy, replace them. Also, make sure the threads are clean, both on the bolts and in the block.
RACE ON!!!
Old Oct 9, 2009 | 05:06 PM
pr0zac's Avatar
pr0zac
RACE ON!!!
not exactly true.. 96-97 lt1's and lt4's had torque to yield bolts.. you need new head bolts
Old Oct 9, 2009 | 07:56 PM
ol school's Avatar
ol school
Hmm well there seems to be a conflict of opinions on weather to replace
the head bolts, I just picked up my heads from the machine shop,he
didnt think i needed to replace them,but because ive heard two differant opinons, ive decided to replace them i figured at $35.00 was a small price to pay .... hoping to install tomorrow
Old Oct 9, 2009 | 08:52 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I was told my '85 had TTY bolts and I figured what the heck I've re-used head bolts lots of times. I had done the entire torque sequence three times and on the last bolt of the last sequence the dirty sob broke. You made the right move getting the new headbolts. If they are ARP, be sure and use the washers and the lube that comes with them, if they are another brand then 30 wt. motor oil will work as a lube.
Old Oct 10, 2009 | 02:24 AM
CFI-EFI's Avatar
CFI-EFI
If that is true, I have learned something new today. I know TTY head bolts to be bolts that have a torque spec of so many ft.lbs. of torque, plus a given number of degrees of rotation. I was not aware any of the LTx engines had TTY head bolts, in any years. I also didn't know that the 1997 was a C4 or that it had an LT1 or LT4 engine available. Had the OP specified a year, my initial answer might have been somewhat different. I stand corrected. Thank you.
RACE ON!!!
Old Oct 10, 2009 | 04:41 AM
93 ragtop's Avatar
93 ragtop
Look at a service manual and see what they say the torque setting is. As I had posted earlier, they changed to the torque to yeild bolts. ( I called them stretch bolts :o) in the latter model LT1.
But if the torque for your car shows something like torque to 15lbs, then turn each 1/4 a turn etc. Do not reuse those bolts.
Most people I know, replace the bolts with ARP head bolts, and then use the earlier torque settings.
Old Oct 10, 2009 | 06:37 AM
floridamale's Avatar
floridamale
RACE ON!!!
The LTx engine was used in the GM F - Body in 97, not the C5 which began its model run in 97.
To reinstalling heads
