I had a curious problem last year... Every so often, after hard driving and shut down, once I restarted and drove normally, the car seemed to hang on 7 cylinders... Once I got on it even a little, the motor would jump right up to all 8 cylinders and run just fine... This only happened once a month or so for a total of 3 or 4 times all summer... Anyone know what this might be??
Initially, it seemed to me to be the fuel system for sure... I did buy a set of accel injectors but before I go toss them in, I want to be sure nothing else is required to run them in my car... It is an 89 6 Speed Ragtop bone stock right now... I have no problem dropping them on, just want to know if I can use the factory pump and regulator with these new injectors... Not looking for much more performance, just a smoother acceleration I guess would be the best way to put it... Car is almost fast enough for my needs...
