L98 without TPI
Old Oct 14, 2009 | 02:53 PM
ddahlgren's Avatar
ddahlgren
Default L98 without TPI
How much power switching just the manifold to a single plane? Same cam heads etc. or just a waste of time? Yes I know it will need a tune.
Old Oct 14, 2009 | 03:04 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
By single plane do you mean carb intake?
Old Oct 14, 2009 | 03:22 PM
ddahlgren's Avatar
ddahlgren
Yes a single plane carb intake with probably the stock throttle body or larger if deemed needed. I can easily fab the elbow adapter as I am in the manifold biz with welders cnc etc..
Old Oct 14, 2009 | 07:24 PM
rodj's Avatar
rodj
Got to have similar effect as running a short runner intake like a MR
Is the prefered method for guys running big cube SBC's.Have put bosses in a SP and used 90 degree hat or made custom plenum.
Old Oct 14, 2009 | 11:31 PM
ddahlgren's Avatar
ddahlgren
Same as a MR meaning a loss in torque in the mid range and more top end? I had thought the ZZ4 used the same head thogh might be wrong there. Looking for 400 ft lbs and 375 hp or so in the end. Max rpm 5800.
Old Oct 15, 2009 | 12:03 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Honestly, 5800rpm is pretty much dead nuts super ram territory. I don't know if you'd hit 375horse with it, but you can hit the tq (+) for sure. Lingenfelter claimed about those numbers for a 350 with the super ram, 219 LPE cam and ported 113s (yes, zz4 heads.)
However I've mostly seen the single plane on big cube SBCs and blown applications, I've been wondering how it would do on smaller motors.
Calderone's Avatar
Calderone
what cam do you have ?
i suggest cam/head/intake/headers upgrade
Old Oct 15, 2009 | 12:48 AM
ddahlgren's Avatar
ddahlgren
I just put on a Borla exhaust, front y pipe with no precats and a Magnaflow cat. It does have loud going for it now.. LOL.. But in driving around it feels great around town but when you get on it it starts to get going pretty good then nothing LOL at about 4 k rpm it seems to just give up the charge so lack of top end power in my mind. The usable power band seems to be 2k to maybe 4200 rpm then a black hole of ho hum nothing. It has new cap rotor plugs wires fuel filter O2 sensor trans fluid and filter rear end lube w/positracion fluid R134a underdrive pulleys. If it would pull as hard from 4k to 6k as it does from 2k to 4k it would be a lot more fun to drive. Looking at the GM website the ZZ4 seems to offer a ton more performance. My thoughts being the intake used was a simple single plane unit and slightly more cam. I am not real game on changing the cam yet but the intake swap seemes easy enough. After the endless Magnaflow exhaust debacle I am up for some simple things to do. It would also be a good place to start i think learning about tuning the 91 SD ECU. Brakes are next anyway but planing for winter projects. In the end i am sure heads and a better cam a must just not in the cards for me in $$$$...
Old Oct 15, 2009 | 03:39 AM
rodj's Avatar
rodj
Once you take the TPI off it is just another SBC limited by whatever heads / cam it has.
My take on it.
Going to a injected SP intake will have the same effect as putting a carb on. Engine will rev much higher.
But the 1st limitation will be the stock cam which is very wimpy because it is designed to work with the TPI which maxes at 4800.
Yes it will rev higher but will it make more power????
Old Oct 16, 2009 | 05:03 AM
ddahlgren's Avatar
ddahlgren
My take on it.
That was pretty much the original question.
Does anyone know the spec for a stock L98 cam?
Old Oct 16, 2009 | 10:10 AM
Calderone's Avatar
Calderone
Here ya go :
Stock L98 cam
Duration @ .050", 202/207 Lift: .413/.428 , 114.5 LSA
Old Oct 16, 2009 | 11:05 AM
ddahlgren's Avatar
ddahlgren
Here ya go :
Stock L98 cam
Thanks that gives me something to compare others to. Geez 114.5 lobe separation..LOL
Old Oct 16, 2009 | 11:12 AM
redrose's Avatar
redrose
congrats...you've just (re)discovered ''the wall'' that us 'ol ferts' found back/day with 305 targeted tpi on a 350...trash that 305 intake and put an intake from an lt1 on, car runs sooo much better, PULLS all the way to 'lifter float'.
Old Oct 16, 2009 | 11:38 AM
Alex Annapolis's Avatar
Alex Annapolis
Thats crazy! I was planning on changing my exhaust soon, so far everyone has said this is the first upgrade worth doing for not a lot of cash. Ive never heard anyone say that swaping exhaust killed their top end, my understanding was an increase in power through the whole power band. So was your car stronger 4k rpm and up before the swap?
Old Oct 17, 2009 | 03:54 AM
ddahlgren's Avatar
ddahlgren
The exhaust change was good just looking for the next step I want it to pull hard to red line rather than one sweet spot then nothing after. I am pretty sure a TPI issue as previous person mentioned.. I looked at the ZZ4 specs and caught my attention that it used the same heads and a 350 the reason for this post..
To L98 without TPI
