I just put '08 wheels on a '94. I think the '08 is the same as the C5???
'08 wheels are 18-19 inch wheels
If they are in fact the same, you will need to put a 1/2 inch spacer on the rears only. The tires will rub on the suspension if you don't gain clearence on the inside of the tire.The fronts fit fine. I also changed the lug studs on the rear to ARP 1/2 inch longer than the stock. The lug nuts only grabed on about 3 threads of the stock stud with the spacers and I didn't feel that was enough to be safe. The longer lugs can be installed without removing the hub from the car but you have to grind off a flat spot on one side of the stud head for clearence past the hub assembly on the back of the rotor. I checked with
ARP engineers to be sure I would not weaken the stud. Just grind slowly so as not to heat the stud. PS They look great with the new wheels on the 94.
Reason: add wheel size
I'd like to see that as well. There is a local guy that is trying to sell me a set for my '84...I know the spacing is different, but I'd like to see how they look.
if you use 1/2'' spacers, longer studs or not you must check that all five lugs are present on each wheel every time you drive the car... stud breakage is likely after only a few miles...btdt, no 'theories'
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I`ve been told that adapters are much better/safer than spacers
The studs I used are ARP race quality studs and are harder and better quality than a stock stud. The 1/2 spacer does put some extra strain on the studs and yes, it is a good idea to always check them for the proper torque on the lugs. The adapters are quit a bit thicker than the spacers because there has to be room for the nuts to hold on the adapter and not interfere with the wheel itsef from sitting properly on the hub. I don't see a need to go any wider than the 1/2 ,it still gives good clearence to the body panel and does clear the inner fender well and suspension. I started with larger fender washers ,1 at a time on each stud until I got the correct clearence and then went with the 1/2 inch spacers when I got the total thicness I needed.The tapered lugs that are on this type of wheel does a pretty good job of centering the wheel on the hub and I haven't felt any change in the balance and the car still handles about the same. The only thing I did feel was that the run flats are quite a bit harder and the tires break loose easier on a hard accelleration.
