Performance axle on 96??
Old Feb 24, 2002 | 08:07 PM
creepingvette's Avatar
creepingvette
Default Performance axle on 96??
What kind of difference does the performance rear axle option on the '96 A4 have? It was only $50, so I wouldn't imagine it was a big difference. I've just always wondered, thanks. :chevy
Old Feb 24, 2002 | 09:38 PM
Half Fast's Avatar
Half Fast
Default Re: Performance axle on 96?? (creepingvette)
3.07 instead of 2.59 gear ratio.
Old Feb 24, 2002 | 09:57 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
If you ever dove one with the 3.07 you would see a BIG difference.
Old Feb 24, 2002 | 10:08 PM
creepingvette
Well, the only '96 that I have driven has the 3.07 gear ratio, so the only comparison would be to drive one with 2.59's. Too bad I can't see what it does at the track, Dad won't let me. :cry :cry :cry
Old Feb 25, 2002 | 12:00 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
:yesnod: :yesnod: :yesnod:
Old Feb 27, 2002 | 06:15 PM
creepingvette
What kind of times could a healthy A4 LT1 with the performance axle run? Im dying to find out myself, but can't convince Dad to bring it to the track :rolleyes:
Old Feb 27, 2002 | 08:46 PM
emoshn's Avatar
emoshn
Don't know for sure on a 94. But on my 92, I have 2 codes for rear diff. I have G92 (which indicates I have a performance axle) and GU2 which = 2.73. I mention this because all my window sticker says is "Performance axle...$50", My build sheet shows the performance axle code and the ratio code.
If I'm wrong, tell me I have a 3.07...please.
Old Feb 27, 2002 | 09:12 PM
Springer's LT4
Default Re: Performance axle on 96?? (emoshn)
I can lie to you if ya want... but you have 2.73's :)
G44 is the 3.07 rear
Old Feb 28, 2002 | 06:39 PM
creepingvette
Default Re: Performance axle on 96?? (Springer's 95)
So Half Fast was wrong?? :confused:
Old Feb 28, 2002 | 07:00 PM
Half Fast's Avatar
Half Fast
He's talking about a '92. For 1996 a LT1 automatic with RPO code G92 (performance axle) should also have the code G44 (3.07 gear). Half Fast is rarely wrong. :cool:
Old Feb 28, 2002 | 07:42 PM
creepingvette
Default Re: Performance axle on 96?? (Half Fast)
Thanks a lot!! I'm glad you are rarely wrong. :D :D :D :D :D
Old Mar 1, 2002 | 12:32 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Ok guys, here it is. The rpo G92 was a marketing code for the performance axle option. Stock autos came with rpo GM1 which is the dana 36 with 2:59 gears. If you had G92 you would also have either rpo GU2 (dana 36 with 2:73 in the verts) or G44 (dana 36 with 3:07 in the coupes). The six speed cars (both verts and coupes) would have GM3 (dana 44 with 3:45). :cheers:
To Performance axle on 96??
