Help me with this cam card!!
Old Feb 28, 2002 | 10:45 PM
Corey_68's Avatar
Corey_68
Default Help me with this cam card!!
Ok in Lingenfelter's book he reccomened a hydraulic (Non-roller)224/234 duration and .465/.488 lift with 114 lobe seperation for a 383. I'm confused, is this cam a 224/234 or is it 282/292??? The Ed Wright chip is coming in tomorrow and we cranked the car today with the stock chip to check everything and it has a pretty radical idle. Will the chip take care of some of this? It's running rich with the 30# injectors.
The car in question is a '86 coupe 383, with this cam, 2.02 heads, etc
Here's the card......
[Modified by Thad, 9:17 PM 2/28/2002]
Old Feb 28, 2002 | 10:52 PM
BBA's Avatar
BBA
Default Re: Help me with this cam card!! (Thad)
Is a very mild cam, almost the same as the C3 L82 cam. You do NOT need the 30# injectors with this cam.
But look at the bright side... Should make at least 250 HP. :(
[Modified by BBA, 9:54 PM 2/28/2002]
Old Feb 28, 2002 | 10:55 PM
Corey_68's Avatar
Corey_68
Default Re: Help me with this cam card!! (BBA)
I had a comp cam 268H in my '68 Stingray and this thing sounds way more radical. Ed Wright even said this would be a good cam when I spoke to him? :confused:
Old Feb 28, 2002 | 11:14 PM
EricVonHa's Avatar
EricVonHa
I agree with the second post that the cam is mild... with that 383 you should be over .5" lift and a hair more duration. You should be able to get 450hp easy if you go with the larger cam.
Old Mar 1, 2002 | 01:03 AM
BBA's Avatar
BBA
Default Re: Help me with this cam card!! (EricVonHa)
I think you should consider using a roller cam as well.
Now a roller with the same spec's ( well...maybe with more lift ) will give very good performance...maybe at the 400-430 HP level, and even run smoother.
To Help me with this cam card!!
