"SYS" flash
Old Oct 16, 2009 | 06:58 PM
55c3pu's Avatar
55c3pu
3rd Gear
Default "SYS" flash
93 with 21000 miles. The speedo section that displays MPG alternately flashes "SYS". All the manual tells me is to see the dealer. Scan tool shows all systems normal, no codes stored. What is causing this?
Old Oct 16, 2009 | 07:23 PM
STL94LT1's Avatar
STL94LT1
Probably a weak battery.
Old Oct 18, 2009 | 07:09 AM
GS023's Avatar
GS023
Charge it up!
Old Oct 18, 2009 | 12:04 PM
robslittleoldv8's Avatar
robslittleoldv8
2nd Gear
The sys message is due to codes stored in your ccm. They wont always set codes if they are for something minor like your climate control. Pull the flash codes using the technique in the GM service manual. Rob
To "SYS" flash
