Can you ID these headers?
Old Oct 16, 2009 | 08:35 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Can you ID these headers?
They are supposedly 1 3/4" headers by TPIS???
Circumference of the primaries is roughly 6".
Anybody seen these before? I have my thoughts but I will keep them to myself...
TIA
Old Oct 16, 2009 | 09:49 PM
speedoholic's Avatar
speedoholic
If they are SLP's they will have SLP logo on the somewhere. My headers on my 99 camaro have a welded plate on them that says "SLP"
Are they any numbers or words on them anywhere?
Old Oct 16, 2009 | 11:00 PM
AKS Racing's Avatar
AKS Racing
They look like my old TPIS long tubes....
No identifying marks on mine anywhere, but they were purchase by me from TPIS.
Old Oct 16, 2009 | 11:28 PM
USAsOnlyWay
No marks anywhere.
Really Aaron? Huh, very VERY interesting. I thought they might be LPE 1 3/4 longtubes as they are the exact same pipe layout as my LPEs.
Do you have any pictures of yours to compare these with?
I love my LPEs but with my angle plug (non-l98 angle, not straight) Dart heads (Dart has the only heads apparently that have this problem) it is an absolute bear to change plugs, so I picked these up as TPIS says their's don't have interference. (Did TPIS change styles perhaps?)
Thanks for the info, this gives me hope that they will work out after all!
Old Oct 17, 2009 | 03:41 AM
USAsOnlyWay
The weird thing is, I thought TPiS headers used standoffs and the stock exhaust bolts. These are flush just like my 1 5/8" LPEs. They really look identical besides the diameters of the piping.
Does anyone have pictures of 1 3/4" LPE longtubes?
Old Oct 17, 2009 | 04:55 AM
Firevette's Avatar
Firevette
Cruise-In X Veteran
I can tell you 100% that they are not the current TPIS design, no idea on the posibility of older versions.
Mine.
Old Oct 17, 2009 | 08:14 AM
JackDidley's Avatar
JackDidley
Mine.
My TPIS are 5 years old and look like Firevettes.
Old Oct 17, 2009 | 09:38 AM
cumbercr's Avatar
cumbercr
They certainly don't look like my TPiS headers. The pipe routing is different, the emissions air tubes are different. Mine don't have air tubes to #7 or #8 pipes. The EGR looks different too.
Old Oct 17, 2009 | 10:52 AM
larry00's Avatar
larry00
Mine.
Yep my TPIS 3 years old but look the same as these !
Old Oct 17, 2009 | 01:23 PM
USAsOnlyWay
I called TPiS (they were there today!) he couldn't say over the phone but they did change their header design many years ago. I sent him an e-mail with some pictures and he said he'd look on Monday and get back to me on it.
I'm still not sure if they are TPiS or LPEs. Either way, good headers.
Old Oct 17, 2009 | 04:50 PM
cumbercr's Avatar
cumbercr
Changing spark plugs could be interesting. For my TPiS headers, I had to modify a spark plug socket to get the plugs behind the pipes. I shortened the socket and cut a slot down the side so the socket went on from the side of the plug. Then tighten with an open end wrench.
Old Oct 17, 2009 | 11:12 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
http://forums.corvetteforum.com/c4-t...these-are.html
Old Oct 17, 2009 | 11:46 PM
USAsOnlyWay
Yeah, I have identical bends in my LPE 1 5/8" headers right now. I also mocked them up on 113s as well. The 113s were fine, my Dart-Specific Angle heads work too, but are a bit of a pain. If I had L98-angle (such as stock) or straight plug heads I would be fine.
Originally Posted by GREGGPENN
http://forums.corvetteforum.com/c4-tech-performance/2098924-anyone-know-which-headers-these-are.html
Thanks Gregg, LPEs were my assumption too. The odd thing is that those headers have the exact same flange as my LPEs, these do not have that same flange. Thus why I think they might be something else. Unfortunately, I had a friend pick these up locally and while I told him how to identify TPiS headers, he only measured the primaries (1 3/4") and collector (3") My LPE 1 5/8" fit fine (no frame clearancing like some headers need, etc), no scraping, room for the old and new starters, have a thick flange and have been real quality pieces so if they are LPEs equal length headers I'll be happy with that too.
I sent an e-mail to TPiS so we'll see what they say.
Either way a set of headers will be up for sale soon probably. Either LPE 1 5/8" or LPE/TPiS 1 3/4"
We'll see!
Old Oct 18, 2009 | 12:41 AM
5abivt's Avatar
5abivt
Don't look like TPIS new design and definitely dont look like LT1/4 headers.
Maybe you guys having plug issues with TPIS have the older design? I should make a video of how fast I can do them on my 93. If I tried I can probably speed all the plugs out and in in less than 10 minutes with no fancy tools.
Old Oct 20, 2009 | 11:39 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by USAsOnlyWay
I had a friend pick these up locally and while I told him how to identify TPiS headers, he only measured the primaries (1 3/4") and collector (3").
We'll see!
Ugh...If they were measured at 1 3/4", how could they be 1 5/8"? Sounds like you have you're answer.
Old Oct 21, 2009 | 02:42 PM
USAsOnlyWay
No no no.
I have LPE 1 5/8" headers already. So, either those or these LPE/TPiS 1 3/4" headers will be up for sale. Get it? (two sets of different headers)
The headers in the pictures are definitely a 1 3/4".
As to whether they are TPiS or LPE, I believe they are an older TPiS design. They are the same design as LPE and Stainless Works headers, merely, they all use a different style of flange.
Old Oct 21, 2009 | 05:06 PM
USAsOnlyWay
If someone is using these headers on an LT1 they will have many problems. They are designed specifically for the L98, one 02 sensor, L98 EGR ports etc...
I'm glad your new LT1 TPiS headers work on your LT1 but that has no relevancy here. Thanks though.
To Can you ID these headers?
