C5 wheel width/offset
Old Oct 17, 2009 | 07:32 AM
The Bus's Avatar
The Bus
Default C5 wheel width/offset
What is the C5 18" wheel width and offset
Thank you for info
Old Oct 17, 2009 | 07:28 PM
c92vette's Avatar
c92vette
You might have better luck with this question in the C5 forum. Just cut and paste it over there. Good luck.
Old Oct 17, 2009 | 08:33 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
How's this?
The rears fit from Corvettes 88 up and the rears fit 84-87 with a 1" wheel spacer.
I think 36mm offset
Old Oct 18, 2009 | 12:50 PM
TJM's Avatar
TJM
Thank you for info
9.5" & 63MM
FYI late C4 is 56MM Early is like 38MM
There is a whole chart of this info in the FAQ sticky.
TJM
Update: The Tech FAQ has the right info
C5 base 8.5" 56mm
9.5" 65mm
Z06 9.5" 54mm
10.5" 58mm
Old Oct 18, 2009 | 09:11 PM
mechguy79's Avatar
mechguy79
Thank you for info
18x9.5 on a 56mm offset. I think I know what you are getting at and I already did it. I run the 18" C5 wagon wheels on all four corners without a problem. If you keep the original C5 tire sizes then your speedo is off 4%.
To C5 wheel width/offset
