What's causing this stain?
Old Feb 24, 2002 | 08:57 PM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Default What's causing this stain?
Every time I clean the car, I need to clean off this stain under the hood. It looks like something's being thrown off the serpentine belt. The car never gets driven in the rain, so the liquid must be coming from somewhere in the engine compartment.
Any ideas?
Brad
Old Feb 24, 2002 | 09:02 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: What's causing this stain? (GS Ragtop)
Actually, it looks like a steam pressure spray. Check the hoses going into the throttle body and intake. It looks like a pin hole spray under high pressure. I don't think it's the belt because it would have an arc pattern.
Old Feb 24, 2002 | 09:40 PM
Andy1983's Avatar
Andy1983
It looks like uhh.... nevermind, can't say it. That would be immature :crazy: :D
I got mine w/ 8k miles, and checked underneath. I gaurantee you this previous owner never cleaned the engine once. I had that on mine, but it wasnt NEAR as bad. It was extremely light and very small. Maybe 1/10-20th less.
Old Feb 24, 2002 | 09:48 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Water pump, happened to me and it happened to Mackey.
Old Feb 24, 2002 | 09:50 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VII Veteran
Default Re: What's causing this stain? (Mr Mojo)
:yesnod: :yesnod: :yesnod: :yesnod:
Old Feb 24, 2002 | 09:58 PM
GS Ragtop's Avatar
GS Ragtop
Aw shucks. Looks like I'd better get busy before I need to add an OptiCrap to the shopping list.
Brad
Old Feb 24, 2002 | 10:12 PM
Mr Mojo's Avatar
Mr Mojo
Wouldn't hurt to do the opti while you are at it, how many miles?
Old Feb 24, 2002 | 10:16 PM
GS Ragtop's Avatar
GS Ragtop
'Bout 33K, adding about 3K per year. It stays a weekend warrior while I travel during the week. :cry
Brad
Old Feb 24, 2002 | 10:27 PM
FIBERGLASMD's Avatar
FIBERGLASMD
It could be coming from the air bleeds that are under the throttle body. There are two of them that you open when you fill the cooling system. They would act like a pin hole under high pressure if they are not tightened up. This would be better than the water pump to fix. Just a thought.
To What's causing this stain?
